Transfer Case Oil change
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Transfer Case Oil change
    September 4th, 2012
    New York
    93
    Hi Folks,
    Anybody here have detail instruction?
    How many quart do I need? Do I need a new drain plug and fill plug?
    Royal Purple make transfer case oil or I have to get the oil from the dealer?
    I did a search but cant find anything.
    Thank you.
    September 12th, 2007
    5,216
    Re: Transfer Case Oil change
    Its only 1.5 qts--use the LR spec. The spec says Shell TF 0753. Perhaps someone can confirm this but IIRC its fill until spill. I think.
    '08 RRS HSE Stornoway Gray
    Premium Member dantheman1's Avatar
    November 18th, 2010
    Miami, FL
    690
    Yup! It's around 1.6 quarts but LR says just fill to level of fill plug. I'd stick with using LR tcase fluid, was around $19 a quart from my dealer.
    2011 RRS Supercharged, Santorini Black on Tan, ATB front and side grilles
    2008 RRS HSE Lux (sold), Alaska white on Ivory/Ebony, Supercharged front and side grill's,
    20" genuine stormer wheels, Supercharged front Brembo brake retrofit, Supercharged exhaust tips retrofit, 2010+ tail lights retrofit, Nappa leather steering wheel retrofit.
    2005 LR3 HSE (sold), Java Black on Alpaca, oversized all-terrains, LR genuine expedition roof rack, grille guard, and tail lamp guards.
    September 4th, 2012
    New York
    93
    thanks for the quick reply.
    Do I need a new drain and fill plugs from the dealer?
    are there any torque spec?
    SOPHOMORE ROVER 52tele's Avatar
    April 13th, 2012
    Charlotte, NC
    436
    You might want to find a good independent mechanic. The. Risk might out weigh the reward here.
    2011 L322 HSE Santorini Black / Tan
    2012 BMW X5M
    2007 Ferrari F430 Coupe. Nero Daytona over Charcoal Leather..under 8,000 miles
    2008 RR Sport.. sold
    June 24th, 2012
    canada
    562
    I did mine about a month ago. Pretty straight forward. I got the fluid from the dealer because you can't seem to find out much about it or a substitute. No new plugs or anything and torque was just tight.
    FRESHMAN ROVER Armogida's Avatar
    September 25th, 2012
    Philadelphia, PA
    188
    You can use royal purple synchro max I believe. That's what I used and its perfect. If you do a search there is a write up on royal purple for the diffs and transfer case. Ill check my garage tomorrow at check back with exactly what I used.
    Java Black 2006 RR Sport S/C
    Philadelphia, PA
    188
    Quote Originally Posted by 52tele View Post
    Changing transfer case fluid is as straight forward as it gets, even easier than changing the oil/filter.
    Premium Member Frisco_TX_RRS's Avatar
    April 8th, 2007
    Frisco TX
    1,187
    I would use OEM fluid
    Royal Purple is only safe on the differentials, they too state to use OEM in the transfer case: http://royalpurpleconsumer.com/wp-co...ence_Chart.pdf
    I've checked several companies and no one has the transfer case alternative for RRS.
    Also, its 1.5 QTS \ fill till it spills.
    Pretty straight forward, can reuse both the drain and fill plugs. Only thing is I found out that you need to pump it in slow else it drains out if you do it too fast.
    22Nm / 16lb.ft for each plug
    Attached Files Attached Files
    Last edited by Frisco_TX_RRS; November 23rd, 2012 at 04:27 PM. Reason: Added attachment
    Philadelphia, PA
    188
    Unless I am misreading that RP cross referance sheet is for transmissions, not transfer case. I spoke with 2 reputable Indy shops as well as my local LR dealer and they all said you could use a variety of fluids, not just the OEM. Also spoke with the RP rep directly via phone. Not trying to start an arguement here as I don't care what people use. Take it for what it's worth.
    Quote Originally Posted by Frisco_TX_RRS View Post
    September 4th, 2012
    New York
    93
    The transfer case drain n refill. pdf stated I need to use new sealing washers for the drain and fill plug.
    Im going to my local LR dealer Monday to get 2 quart of transfer case oils. Do I need to get the sealing washers?
    Philadelphia, PA
    188
    I cleaned and reused mine. No leaks.
    December 6th, 2011
    Philly
    65
    I had my transfer case oil changed at Jiffy Lube on my 2008 HSE. I am not sure what oil they used. I presume it's not what is mentioned above. Do you think this is an issue or will be?
    April 13th, 2012
    Charlotte, NC
    436
    I wouldn't let Jiffy Lube come within 100 feet of any of me cars. If I were you, I would redue the service ASAP, and hope in the proses they didn't strip and or overtightn the plugs! Especially since you don't know what type fluid they used.
    2012 BMW X5M
    Philadelphia, PA
    188
    THIS! Please.
  1. 08 RR HSE Needs New Transfer Case- Really???
    By ejfiii in forum Range Rover Mark III / L322
    Last Post: November 20th, 2012, 06:08 PM
  2. When to change Transfer Case fluid???
    By Jocofire1 in forum Range Rover Mark III / L322
    Last Post: January 27th, 2012, 10:27 AM
  3. p38 transfer case ??
    By mcnabj in forum Range Rover Mark II / P38
    Last Post: December 18th, 2006, 10:14 PM
  4. Transfer Case
    By ipk712 in forum Range Rover Classic
    Last Post: November 24th, 2006, 06:53 PM
  5. Transfer Case Help!
    By Bigbeardbiii in forum Range Rover Mark II / P38
    Last Post: April 7th, 2006, 01:51 PM
