Driver's side blows only cold air out. Heater works only for passenger side.
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Driver's side blows only cold air out. Heater works only for passenger side.
    November 10th, 2012
    United States
    I got a 2008 Sport HSE.
    All the heater/cooler controls seems like working ok (flow direction, auto, etc...)
    BUT THE PROBLEM: driver's side blows only cold air out. Heater works only for passenger side.
    Please help.
    I'm not a mechanic or anything, so if anyone has some pics to support the theory - that would be great.
    September 12th, 2007
    5,216
    Re: Driver's side blows only cold air out. Heater works only for passenger side.
    '08 RRS HSE Stornoway Gray
    November 10th, 2012
    United States
    That is different problem. The guy describes that his is left with only 2 working vents.
    IN MY CASE: All 4 vents working fine. Just 2 (on the driver's side) are blowing COLD AIR ONLY. No heat comes out (if heater is on).
    Thanks.
    5,216
    1. There are possibly stored DTC's (i.e., bad temp sensor), but maybe not. But it's a good place to start.
    2. Start with the easy stuff first--cabin air filter not blocked, cabin temp sensors not covered in belly lint, etc.
    3. Then you get to the blend motors/actuators--I mentioned this as a good place to look because this has been a problem in older RR's and has popped up a couple times here. There are flaps that control the flow of air from the fan AND flaps that control the flow of air over the heater core or evap for both the driver and passenger side.
    November 10th, 2012
    United States
    Thank You. Will try to resolve this.
    5,216
    Good luck with the repair and please check back with what you found.
    March 8th, 2011
    Oklahoma city, OK
    184
    I am experiencing the same exact thing drivers side blows cold air whiles the passenger blows hot! Please let me know if you had any luck fixing this issue
    06 Range Rover Sport Supercharged
    10 Infiniti fx 35
    September 14th, 2012
    NOVA
    418
    same happens to me! ^
    Driver side blows cold air, but after 5-10 min it starts becoming hot
    Premium Member Frisco_TX_RRS's Avatar
    April 8th, 2007
    Frisco TX
    1,214
    Any resolution on this - mine just started to do this yesterday. Not looked at any of the possible problem paths listed above yet
    March 8th, 2011
    Oklahoma city, OK
    184
    No solution yet? All four vents will blow air the right driver side /center console will,only blow air that is fairly warm after some time but not to the desired hot temp. for now to keep myself warm I just press the eco button and it seems to heat the air a little bit more through that vent.
    10 Infiniti fx 35
    November 8th, 2011
    NorCal
    33
    Quote Originally Posted by RRSPORT1 View Post
    Same happening with me!
    Judith - 2007 Range Rover Sport HSE + Lux + Ent Pkg
    Beatrice - 2002 Mercedes Benz G500 (Stolen)
    NOVA
    418
    Quote Originally Posted by joeynahlous View Post
    I think the only solution is to replace the left blender motor. I have the same issue, however my dealer quoted me $1600 to fix the problem since they need to remove the dash to access the area. So needless to say I'm holding off untill it totally fail and hopefully by then it will be spring and I wouldn't even use the Heater
    April 8th, 2007
    Frisco TX
    1,214
    I found the instructions for the blend door actuators, states about a 3 hour job, and the dash does not need to come out
    November 18th, 2012
    Maryland
    71
    completely apples to oranges, here, but when this issue popped up on Lincoln LS's, 90% of the time it was the Heater Control Valve aka DCCV (dual climate control valves).
    Again...not disputing the info/posters above, as we are talking about 2 different vehicles.
    SOPHOMORE ROVER 98cruiser's Avatar
    October 21st, 2011
    339
    Quote Originally Posted by Frisco_TX_RRS View Post
    Well how can we get it done Frisco?? any pics and part pricing
    2011 RRS SC, Orkney Grey, Tan interior, 22" rims, roof rack, running boards, supercharged side vents, black lettering, double tip deleted Resonator exhaust. EuroCharged pulley and tuned ECU. 568HP
  1. Driver's Side Mirror Dips But That's It
    By goroanger in forum Range Rover Mark II / P38
    Last Post: September 14th, 2014, 05:59 PM
  2. Heater blows cold too much.
    By umitbat in forum Range Rover Mark III / L322
    Last Post: February 26th, 2011, 09:00 AM
  3. Heater Blows Cold air
    By vjm530 in forum Range Rover Mark II / P38
    Last Post: March 8th, 2010, 07:30 PM
  4. Heater cold one side.
    By Manks in forum Range Rover Mark II / P38
    Last Post: October 17th, 2005, 03:27 PM
