75k Service - Dynamic Response
Results 1 to 2 of 2
Thread: 75k Service - Dynamic Response
    October 4th, 2012
    Greenville, SC
    12
    So, I bought my first Range Rover, an 07 RRS S/C with about 80k on it. Turns out the 75k service was never fully performed, just the oil changed. I got a quote of $600 from both the local LR dealer and an indy shop...surprised they were the same.
    After asking questions and seeing a list of services, the LR dealer did not include the following:
    - Remove debris from Dynamic Response valve block and chassis
    - Replace Dynamic Response valve block filter
    The Indy shop said the following is all they can do to the DR: "The 75K service includes cleaning away any visible debris between the dynamic response valve block and chassis. It does not include any servicing of the Dynamic Response system, such as bleeding the system, etc. You would need to take it to the dealer for that if you are having issues"
    I'm going to perform the 75k service myself, with the exception of the DR work, so 2 questions:
    - Does "remove debris" mean cleaning up the actuating rods on the outside of the system?
    - Does DR filter replacement involve going into the actual system, requiring bleeding? (I would assume so...)
    September 12th, 2007
    5,216
    Re: 75k Service - Dynamic Response
    The debris sounds like a simple wipe down, and I would not touch the DR filter myself--let LR do it if it needs to be done.
    '08 RRS HSE Stornoway Gray
  1. Dynamic Response & Adaptive Dynamic
    By JacekM in forum Range Rover Sport / L320
    Last Post: June 27th, 2011, 06:18 PM
  2. Exactly what does the Dynamic Response software upgrade do?
    By Rob Ward in forum Range Rover Sport / L320
    Last Post: May 24th, 2008, 07:26 PM
  3. Is Dynamic Response useful?
    By RRover in forum Range Rover Sport / L320
    Last Post: August 6th, 2007, 09:40 PM
  4. Dynamic response
    By Prayn4Sno in forum Range Rover Sport / L320
    Last Post: July 12th, 2006, 05:41 AM
  5. Dynamic Response
    By HugeBob in forum Range Rover Sport / L320
    Last Post: April 12th, 2006, 11:01 AM
