This is what happens when...
Results 1 to 15 of 22
Thread: This is what happens when...
    September 12th, 2007
    2,650
    Your dealer replaces the rear differential on your RRS and screws up the camber setting on the alignment.
    '08 RRS HSE Stornoway Gray
    January 8th, 2006
    Houston, Texas
    2,727
    Re: This is what happens when...
    Houston...we have a problem!!! Bummer, but what kind of plain and simple tires are you running there Goose...I don't see any snow studs or other grippy siping to get you thru the snow!
    PJPR - 06 Cairns Blue HSE
    140K - Running like a charm!
    ckp
    ckp is offline
    October 25th, 2011
    311
    whoa that sucks. is the dealer going to make this right by fixing the camber, and new tires?
    2,650
    Yes, I've admittedly been lax in checking my tires for wear this season but:
    1. We've had no snow..so far
    2. They're what's left of a set of Pirelli Scorpion Ice and Snow's (aka the Nice and Slow's b/c they used to hum very loudly once I hit 75mph). Now that there's no tread left and the cords have been exposed they have quieted down quite a bit but I'm afraid to drive faster than 40mph now.
    But seriously, the fronts prolly have another 7K in them, but these rears just went kaplooey after the misalignment. Compared to other snow tires I've ever owned, these are probably the worst tires I've ever put on one of my cars. To anyone considering them on this car, I would say stay away.
    December 25th, 2011
    NJ USA
    4
    I've had great luck with Conti DWS tires here in NJ under all sorts of weather conditions (not in my new-to-me RRS, but in 2 rear-drive BMW's). Plus, they have a 50k mile warranty.
    2,650
    Quote Originally Posted by JasonF View Post
    Ha..ha. That's what's going on Friday. I'll let you know what I think after they scrub in.
    January 16th, 2007
    Boise, ID; USA
    1,260
    Goose, how much was the camber off? I have the same snows and I'd have to say that if I wore them to the cords, they'd probably look similar. I don't even see the sipes on your outer tread anymore - aren't they way past usable?
    '07 RRS
    '03 325i
    '94 GSX
    2,650
    Quote Originally Posted by TripleE View Post
    I'm not sure. I suspect there is an issue with toe here as well. Maybe a combo of too much negative toe and negative camber? I'm gonna find out what the settings are this Fri as I am taking the rig to a guy who does alignments on race and track cars to see what's going on.
    What's wacky is I had the tires rotated before the rear diff was changed about 10K ago and the wear on the front/backs was roughly equal. Both fronts are in good shape still--probably another 7K or so, while the backs are...So something is causing the backs to wear very quickly after that diff change.
    There was the issue with nebulous "bush settle" that LR had with the LR3/RRS early on in which they admitted there was a tire wear issue but never admitted any problem to on their part. The wear or these is similar. So, IDK. Btw, hard to tell in the pic but the outside tread is just a thumbnail above the wear indicator.
    January 19th, 2010
    33
    Here's another thought... I had the same issue and blamed the dealer after two sets of tires that wore evenly and got about 35K out of them both. Put on the third set and the dealer talked me into an alignment and all of a sudden I was ripping through rears, as in your photo, seemed out of camber in 10K. They replaced them once and realigned. Worn out again in 8K. Turned out to be the rear ball joints...problem solved. Very odd how it would seeming go bad so fast and coincidently timed with the intial alignment. Give it some thought... they were bad.
    March 8th, 2011
    Oklahoma city, OK
    124
    gooseyloosey i aligned my car at master tech two days ago they used that hunter technology alignment machine, they were able to pull out the factory alignment ratio's, lets see if your numbers match my numbers that i have.it shouldnt be different if if its a hse or supercharged right? the picture of the results isnt too clear.
    Attached Thumbnails Attached Thumbnails This is what happens when...-photo.jpg
    06 Range Rover Sport Supercharged
    10 Infiniti fx 35
    January 16th, 2007
    Boise, ID; USA
    1,260
    Ah ok, I'm down to the wear indicator on the outside also, but my inside isn't near cording, just no siping left on the inside.
    '07 RRS
    '03 325i
    '94 GSX
  13. #12
    FORUM ADMINISTRATOR umbertob's Avatar
    8,254
    Factory alignment targets - both front and rear - enclosed. All Range Rovers up to MY2012 are included, not just the Sport (sorry).
    Attached Files Attached Files
  14. #13
    2,650
    Thanks for all the help guys! I'll have the mech check those ball joints while the wheels are off and hopefully have a better idea what's going on after the alignment this weekend.
  15. #14
    2,650
    Ok. The results are in.
    Camber:
    D was -1.9 deg-- slightly out of spec
    P was -1.7 at the upper end of spec
    Toe:
    -.41 on both sides (WAY out of spec, as spec is for slight + toe)
    Looks like the toe was the major culprit here and aided and abetted by the camber.
    Apparently the dealer hired the town drunk to do alignments.
  16. #15
    January 2nd, 2012
    Renton, WA
    11
    Are they going to make it right for you concerning the lost tire wear?
