Hdc fault system unavailable
Results 1 to 8 of 8
Thread: Hdc fault system unavailable
    August 28th, 2006
    Rowland Heights, CA
    77
    When I start up my Sport when its cold it throws at fault: HDC FAULT SYSTEM UNAVAILABLE
    after a few seconds it dissapears.
    Has anyone had this issue? Any way to fix this?
    Thanks in advance!
    BTW my Sport is a 2006 Supercharged
    2003 BMW 330i ZHP
    2006 Range Rover Sport Supercharged
    2006 Range Rover HSE w/ alot of problems!!!
    November 18th, 2010
    Fort Worth, TX
    186
    Re: Hdc fault system unavailable
    Usually means it's time to change the battery. HDC system and RRS electronics in general are very sensitive to battery voltage, especially at startup.
    Quote Originally Posted by GuNBeeM View Post
    Thanks in advance!
    2008 RRS HSE Lux, Alaska white, Ivory/Ebony interior, fully loaded, supercharged front and side grilles, 20" supercharged wheels, 2010+ tail lights retrofit, complete supercharged Brembo brake retrofit, supercharged exhaust tips + center resonator delete.
    2008 BMW 550i Sport, Carbon Black Metallic, Beige Dakota, fully loaded.
    December 3rd, 2011
    Seattle
    117
    ^ yup, this fixed the same issue on mine
    January 8th, 2006
    Houston, Texas
    2,727
    If you're under warranty still, the dealer will replace. If not, highly suggest getting the new Sears Advanged Gold AGM battery...much better battery, it's Glass Matte technology and won't leave you stranded like the standard battery.
    PJPR - 06 Cairns Blue HSE
    140K - Running like a charm!
    August 28th, 2006
    Rowland Heights, CA
    77
    Thanks for the replies! I better get a new battery before it messes things up.
    Do you guys know how much the OEM batteries go for?
    Thanks!!!
    2003 BMW 330i ZHP
    FORUM ADMINISTRATOR umbertob's Avatar
    8,254
    OEM cell is made by Varta in Europe, a brand that's not available in North America. That's good, because Varta is crap. The equivalent size and type would be a "wet" battery such as the Interstate MTP-H7 (groups size 94R), widely available for about $150, which is what a dealer would likely replace your OEM battery with. A step up in CCA and reserve capacity (slightly longer but still fits comfortably in the battery compartment without any modifications) would be the MTP-H8. I purchased that one after my OEM battery died and it lasted me 50% longer (mileage and time-wise) than the original Varta, so I really like Interstates. Paul's recommendation of a "dry" Absorbed Glass Mat type battery is a good one, though. Sears Advanced Gold (or Platinum) batteries were not yet available in a size compatible with the Sport the last time I shopped around for a battery, otherwise I would have looked at those first. They seem priced competitively with traditional wet batteries of the same group size and have a very long warranty, can't ever spill acid even if they fail (with all the electronic modules tucked around the battery in our engine compartment, that's a big plus) and - on paper at least - should last longer.
    FRESHMAN ROVER Golfer1659's Avatar
    December 23rd, 2011
    Long Island
    153
    You want want either a DEKA or Sears Platinum...........I run a bass boat every weekend 3 out of the 4 seasons year round and travel all over the place with 4 batteries in the boat.
    My main battery is a DEKA Group 31 strictly for startup and running the big electronic units I have. That thing is a beast and charges fast and will last a LONG time......
    I have run through many different batteries until I started using either or of those and have NEVER looked back, those are the probably best starting batteries you can buy............you can drain them all the way down if need be too, but that will never happen with your truck.
    January 8th, 2006
    Houston, Texas
    2,727
    Quote Originally Posted by Golfer1659 View Post
    As I mentioned above, the Sears Gold AGM is the choice for after market battery, as there is no Sears Platinum for the 2006 RRS...
  1. Engine System Fault
    By bbdesoleil in forum Range Rover Mark III / L322
    Last Post: October 21st, 2011, 01:10 PM
  2. lazy locking unavailable on 08 model??
    By theghostofsmokeyjoe in forum Range Rover Mark III / L322
    Last Post: June 7th, 2010, 11:37 AM
  3. Engine System Fault
    Last Post: October 23rd, 2007, 08:27 AM
  4. TSB - Engine System Fault (S/C only)
    Last Post: July 9th, 2006, 11:09 PM
  5. HDC System Fault
    By caporajm in forum Range Rover Sport / L320
    Last Post: December 4th, 2005, 02:41 AM
