Buzzing-like vibration in steering wheel; getting worse
Results 1 to 11 of 11
Thread: Buzzing-like vibration in steering wheel; getting worse
    FRESHMAN ROVER EstorilM's Avatar
    October 24th, 2011
    Chantilly, VA
    214
    I know I've made a thread about this in the past, but it's really puzzling to me that I can't find out much more info about this problem. My experience with Land Rovers (ie. my Discovery II) was that they're VERY consistent with their issues. This has been my case with every problem I've ever had with both vehicles, except for this.
    Between 45-55 I get a REALLY annoying buzzing-like vibration through the steering wheel; NOT a "thumping" type wheel vibration. It's 110% driveline-related, but I don't know how/why/where it's coming from. I need someone who is very technically adept with these components to really nail this one for me I think, since there aren't too many ways to transmit NVH from the driveline directly through to the steering wheel.
    It's worse when I JUST barely let off the throttle in cruise so the driveline is almost perfectly "slack" - then I get this harmonic humming/vibration feel AND sound. At the right frequency the sound is very noticeable as is the feel (which is the annoying part).
    At this point my list is pretty much the following;
    Front driveshaft
    Front differential
    Front hubs
    Some bushings up there? - not sure what's involved with the front driveline though.
    Please helppppp, it's driving me insane!
    <br>
    '99 Discovery II | 165k mi. | Kinversand | 7 pas, SLS, HK<br>
    '05 Mustang GT Prem. red/red, Shaker 1000| too many mods.. - SOLD<br>
    '06 Range Rover Sport | Atacama Sand | LUX/Cold Weather/Adaptive HL/RSE<br>
    '90 24' Donzi Black Widow | 490hp/620lb-ft tq - restoration
    FRESHMAN ROVER AwfAxis's Avatar
    October 27th, 2010
    Reno Nevada
    249
    Re: Buzzing-like vibration in steering wheel; getting worse
    I call this sensation a harmonic resonance. My theory is that the steering is picking up engine or exhaust notes that work its way through the steering shaft. I've kind of learned to live with it.
    I remember in the old days (when I was 20), I had solid motor mounts on Chevy big-block Nova. The sensation is the same.
    2011 Range Rover Sport GT LE
    2012 Ford F-150 FX4 ECB (Yee-Haw)
    2010 Trek 6000 Series
    2010 New balance 993
    September 12th, 2007
    5,216
    The best I can do on the interwebz is add to your list,
    --steering rack mounts
    --tie rods
    --steering shaft
    But based on your symptoms I would look at the diff first.
    '08 RRS HSE Stornoway Gray
    October 24th, 2011
    Chantilly, VA
    214
    --tie rods
    --steering shaft
    Yeah those had crossed my mind, but it's gradually occurred to me over the months that those components aren't designed to isolate this type of thing - I'm trying to figure out if it's an NVH isolation problem or if something is broken/failing in the driveline (in which case no steering component was designed to "hide" that kinda thing in the first place.)
    The steering feels fine, and the more I thought about it.. no "rotational" driveline type component should really even be in contact with the steering components? The closest would be near the hub area of each wheel, and not the differential, thus any NVH through the diff would need to be sent out through the axles and into the hub where it would be picked up and sent through the tie rods, rack, and steering shaft.
    WTF.. I've diagnosed a lot of stuff over the years with many cars, but this is difficult due to the number of components between the causes (ie driveline) and the effects (the steering wheel). That's like half the car :P
    AwfAxis - if I had that car, I'd learn to deal with it
    <br>
    Premium Member dantheman1's Avatar
    November 18th, 2010
    Miami, FL
    673
    Could it just be that your 22" wheels with low profile tires are emitting more feedback into the steering wheel? I know my dealer gave me crap about running nearly worn out tires on 20" causing some steering feedback, have since upsized a little and the steering/ride is much better. Just a thought.
    2011 RRS Supercharged, Santorini Black on Tan, ATB front and side grilles
    2008 RRS HSE Lux (sold), Alaska white on Ivory/Ebony, Supercharged front and side grill's,
    20" genuine stormer wheels, Supercharged front Brembo brake retrofit, Supercharged exhaust tips retrofit, 2010+ tail lights retrofit, Nappa leather steering wheel retrofit.
    2005 LR3 HSE (sold), Java Black on Alpaca, oversized all-terrains, LR genuine expedition roof rack, grille guard, and tail lamp guards.
    October 24th, 2011
    Chantilly, VA
    214
    Quote Originally Posted by dantheman1 View Post
    Well they're not helping any comfort levels but it's certainly not the wheels (happened since I got the vehicle, even with OE 19's) - but like I said, this is a bizzing-like harmonic frequency. When it's really resonating it comes in ~1sec waves.
    Not even u joints in the front driveshaft would cause that type of sound right? That should also be a thunking-type constant vibration (sure it may get worse at a given speed/go away, but it wouldn't "pulse" in a resonating fashion). I went through two driveshafts in the Discovery II so I know what those are like - absolutely no NHV was ever sent through the steering rack in that case, but the DII is also a live axle so that doesn't mean much. Isolation in general on the RRS should be better however. Maybe gear set within the front diff..
    FWIW I've heard great things about the ZF servotronic system, both in isolation/comfort and reliability. NOT so much with Land Rover differentials and driveshafts though!
    edit:
    Title Front & Rear Differential Noise & Oil Leaks
    Last Modified 03-MAR-2009 12:23
    Category: Driveline
    Symptom: 509000 Axle Concerns
    Content: Front & Rear Differential Noise, Minor Oil Seal Leak & Debris in Oil.
    Concern: Noise (Whine or humming) from the front or rear differential. A minor oil leak may be evident with possible debris in oil. Oil will be black in color.
    Hm I knew about this TSB but only in relation to the rear differential, which is failed on my vehicle as well (confirmed by putting it on the lift and running it in drive - VERY loud bearing noise on rear diff above ~10mph, only noticible in car above 30 or so).
    While the rear diff is a definite "whine" - the "humming" description sounds exactly like what's happening on the front. Depending on the nature of the bearing failure, this makes sense.. a chunk out of a roller bearing would cause this humming noise.
    Anyways as I said, I don't think there another driveline piece up there with components small enough to generate the sound/vibration I feel - narrowing in on the front diff.
    I'll stick a rag in the filler plug this weekend and see what's going on. The rear is black, who knows.. maybe I'll manage to match it up.
    ALSO: What are the odds my extended warranty company will cover this? 368475:1? 4736347694736:1?
    <br>
    January 27th, 2008
    Phoenix (Ahwatukee) AZ
    13
    Did you ever find a solution to this? I was going to post new, but found your message...
    I have a 2006 RRS and last summer I noticed a humming kind of vibration, most noticeable at highway speeds, but only when lifting the throttle. I hear it and feel it through the steering wheel and floor. It has not seemed to get worse, but maybe it's a very slow degradation.
    I had it into the dealer yesterday on some other things, but the mechanic failed to take the car up to highway speed to properly diagnose. I only discovered this after I had left, and I did not want to go back.
    Though the sensation is like a worn bearing, I do not hear or feel sensitivity to braking or turning. But the humming reliably happens every time I'm off-throttle. SInce I'm feeling it through the steering, I'm thinking suspension or bearing rather than drivetrain, but I'm not sure.
    Any luck with your diagnosis?
    Thanks.
    06 RR Sport Tonga Green
    99 Porsche 996 Coupe Zenith Blue
    November 18th, 2004
    Jamberoo NSW Australia
    206
    Hi Randal,
    Posted this some time ago, and it may be of some help to you, Quote:
    I recently developed a very pronounced very and annoying buzzing feedback on the steering wheel of my 2006 RRS.
    The buzz was occurring intermittently but very frequently and it was audible as well.
    Investigating at and around the steering gear I found a small amount of free play on the small input shaft to the steering box.
    The play was very very small and only just barely detectable with the help of a friend moving the steering back and forth, with me under the truck.
    I torqued up the bolt at the coupling, which by the way did not seem loose but I gave it a bit more anyway, by feel only as there was no way I could get my torque wrench to fit in there.
    Happy days followed as the buzz was gone.
    Why did it buzz?
    I really don't know but I suspect that it has something to do with the servotronic valve trying to give feedback to the input shaft and the free play might make it unstable.
    In any case this may not be your problem but it's worth a check if you are experiencing these symptoms.
    Cheers,
    Keijo
    FRESHMAN ROVER Armogida's Avatar
    September 25th, 2012
    Philadelphia, PA
    188
    I have the same issue and will try the above fix. Thx.
    Java Black 2006 RR Sport S/C
    January 27th, 2008
    13
    Thanks, Keijo. By "input shaft to the steering box", do you mean I should look for the the entry point of the shaft from the steering wheel into the steering box? Or does the shaft itself have a u-joint or flex coupling of some sort, and that's where I should look?
    Was your vibration issue strictly off-throttle, more noticeable at higher speeds, like mine? Or was it all the time?
    Thanks again.
    November 18th, 2004
    206
    Hi Randal,
    Sorry for the late reply, but it is holiday season
    The point where I had slack was where the last little universal joint connects to the actual steering box.
    It is below the inermediate shaft.
    The small bolt is actually in the lower section of the universal and tightens onto a small shaft sticking out of the steering box.
    Buzzing-like vibration in steering wheel; getting worse-rr-sport-stering.jpg Item 1 in the sketch.
    My buzzing was intermittent and yes it did seem to coincide with offf throttle somewhat, but more with the steering being lightly loaded.
    Good luck mate, and have a happy new year.
  1. Steering wheel vibration
    By localbrew in forum Range Rover Mark III / L322
    Last Post: February 23rd, 2013, 07:45 PM
  2. Steering wheel vibration on 09 RRS
    By swatson1 in forum Range Rover Sport / L320
    Last Post: December 6th, 2011, 07:08 PM
  3. Steering Wheel Vibration
    By b_arra in forum Range Rover Sport / L320
    Last Post: March 29th, 2010, 08:01 PM
  4. Wheel Balancing, Steering Wheel Vibration
    By lesjonpool in forum Range Rover Mark II / P38
    Last Post: November 17th, 2009, 01:58 PM
  5. Vibration at the steering wheel
    By TheRange in forum Range Rover Classic
    Last Post: March 12th, 2009, 06:18 PM
