Steering wheel/column noise at operating temp
Results 1 to 6 of 6
Thread: Steering wheel/column noise at operating temp
    FRESHMAN ROVER Craig Lnu's Avatar
    June 23rd, 2008
    52
    Not sure if this is the same issue previously discussed, so I figured I would run it by you guys as my warranty expires next week. Recently, a low-level whining noise has begun to emanate from my steering wheel/column - inside the cabin. This ONLY happens once the Sport has warmed up (normal operating temp). When first started and driven - no noise, but once warmed up the noise begins when turning the wheel (standing or driving).
    Any thoughts?
    Thanks.
    2013 RR Sport HSE LUX
    Aintree Green/Almond/Nutmeg
    Front/Rear Lamp Guards, Front Bumper Cover, Body Side Molding, Roof Rails/Rack
    11K miles
    September 12th, 2007
    5,216
    Re: Steering wheel/column noise at operating temp
    First, any more pets we don't know about?
    Check your P/S fluid level first. If thats OK then there's the odd chance the system has some air in it (was the P/S fluid just changed or any work done on the system?)...or possibly the P/S pump is on the fritz.
    '08 RRS HSE Stornoway Gray
    11,026
    All of those, plus PAS fluid may be contaminated. A couple of old TSBs that may be applicable to your 2006, depending on VIN:
    Attached Files Attached Files
    June 23rd, 2008
    52
    Thanks guys - checked the PS fluid level and appears fine - appt. next week, 5 days before warranty expires. Will print out the tech bulletins and mention to the advisor (thanks Umbertob).
    And, as far as I know, my 86lb Doberman hasn't been up front or in the engine compartment
    11K miles
    June 23rd, 2008
    52
    As my VIN was within the LTB00111 range and symptoms paralleled those I identified, I printed it out and simply mentioned it to the service advisor...bingo! Thanks again for posting Umertob, problem resolved! (Adviser mentioned the remedy was the one cited in this bulletin).
    Best,
    Craig
    11K miles
    April 16th, 2015
    Michigan
    Hello everyone! I have a 2006 RR Supercharged. I have recently noticed that after my truck warms up or driven a little distance, there's a whining noise when i turn the steering wheel. As i stated, it only occurs after the vehicle warms up. Has anyone had this problem?
  1. Knocking Noise and Steering Wheel Whistle Noise
    By Jerlew3 in forum Range Rover Sport / L320
    Last Post: July 10th, 2011, 07:25 PM
  2. Whining noise when turning steering wheel to the right
    By JohnSweden in forum Range Rover Mark II / P38
    Last Post: April 10th, 2011, 07:11 PM
  3. Noise in steering wheel
    By darrinturner in forum Range Rover Mark II / P38
    Last Post: January 6th, 2011, 08:51 AM
  4. rough idle when cold and operating temp
    By ajsvls44 in forum Range Rover Mark II / P38
    Last Post: October 13th, 2009, 01:39 PM
  5. 04 RR teloscopic steering wheel noise
    By Klassen619 in forum Range Rover Mark III / L322
    Last Post: April 22nd, 2006, 03:13 PM
