it is above your head. where the cabin lights and sunroof controls are. Pop that panel, TPMS module is right behind it.
I had the same problem, there are numerous articles where people suspecting sensors themselves but it is almost always a module.
Hello all, new 2008 range rover sport owner. I have a question regarding the TPMS system on the RR's. At risk of bumping a old threat i decided to start a new one. I had a TPMS light come on and tell me to check all tires. Came home, filled to proper level of 38/42 in FF RR. Started back up...
www.rangerovers.net
The link above will help you locate the Tpms module
Hello all. New member to the forum. I have had a 2011 Range Rover Sport HSE Lux for three years now. I do not recall the spare tire TPMS alert coming on when you start the vehicle, but it then goes away after a few seconds. I have take my spare tire off and there is no TMPS sensor in it and also inflated to 60 psi. I tried having a local mechanic hook up his device to the OBD port to change TPMS to "no spare" and did not work. I have searched the forum and see nothing specific about this, but surely could use some expert advice. This alert is aggravating. Thank you!
122.2K members
