oil in my coolant reservoir of my Sport 2005
Results 1 to 4 of 4
Thread: oil in my coolant reservoir of my Sport 2005
    October 22nd, 2015
    LIBYA
    7
    I have oil in my coolant reservoir of my Range Rover Sport 2005 . I would like to know where is it come from? Could it just be some oil cooler leaks to water system, cause it has higher pressure than coolant system or some other coolers from the suspension dynamic system. My engine oil is clean ( no water in there), or is it the head gasket or it might be something else entirely ..
    Note: this issue has happened while the car is running in ideal at the garage. there was no indication of over heating the engine. temperature indicator still show normal values even now when I start the engine with the current failure condition. but the oil will be flowing to my coolant reservoir.
    please Gide me to investigate this issue ,I hope it is NOT the head gasket.
    with my best regards ,,,
    Kredegh.
    June 24th, 2012
    canada
    535
    Re: oil in my coolant reservoir of my Sport 2005
    Found this on a google search
    head gasket is when water is in oil which is not that expensive if the engine does not otherheat . If you drive your car and water temperature doesn't go over 100 degrees then your headgasket is ok .And this mean you can have these 2 problems
    1. Oil cooler
    2. Crack in the Block
    If is oil cooler it's easy to change and after you need to clean your water cooling system,after couple good washes(means 10+ ,drain water add new one clean the reservoiar) you change thermostat and water pomp .
    If is the block crack then is cheaper to find another engine instead of repair .
    and this from the repair manual
    There are two engine oil coolers working in parallel. The first engine oil cooler is fed coolant from the bottom hose. Coolant is diverted from between the radiator and the thermostat, directed to the cooler and then returned to the bottom hose. The second oil cooler is cooled by air and is mounted in front of the right hand wheel.
    2009 RRS S/C
    October 22nd, 2015
    LIBYA
    7
    thank you for your information Arby,
    Premium Member Frisco_TX_RRS's Avatar
    April 8th, 2007
    Frisco TX
    1,183
    Saw oil by this hose yesterday. Wondering if this is a potential issue? Seems like oil is leaking down the radiator too.
  1. Low Coolant in Reservoir
    By dantheman201 in forum Range Rover Mark II / P38
    Last Post: July 11th, 2016, 10:24 PM
  2. Replacing Coolant Reservoir
    By bhrr in forum Range Rover Mark III / L322
    Last Post: January 28th, 2011, 09:55 AM
  3. Coolant reservoir 03-05
    By noname in forum Range Rover Mark III / L322
    Last Post: July 31st, 2010, 01:00 PM
  4. coolant reservoir boiling but engine doesn't over heat
    By 420P38 in forum Range Rover Mark II / P38
    Last Post: April 2nd, 2009, 01:20 AM
