I thought I would do a bit of preventative maintenance on my RRS considering the "arduous use" it gets as defined by LR day in and day out. This at 72K miles registered on the odometer, probably closer to 75K considering I'm running oversize tires for at least 45K of the 72k
So...I decided to replace the transmission fluid and front and rear differential fluids...interesting to see how these 3 boxes absorb the wear and tear differently. I had previously already changed the transfer case back around 57K.
1. Rear differential - fluid came out looking like a cafe mocha grande, certainly not clear liquid, but no metal shavings and all gears look good (shining a light into the diff box to see the teeth). Minimal pasty gunk on the magnetic filler plug.
2. Front differential - fluid came out looking like Texas crude - a completely black fluid, a bit more pasty gunk on the magnetic filler plug, but no metal fillings either. Gears look good as well.
3. Transmission - fluid still quite clear, no gunk at all...good sign!
In addition to this, I had my front sway bar bushings replaced - very easy to do, and this solved a very recent clunking sound I was hearing on some rough roads.
After all of this was done - car again is rock solid, no wiggle or clunking at all, smooth as silk...onwards to the next 75K miles!
Total Cost: $325 for parts and labor done at Land Rovers Unlimited (Independent shop in the Woodlands)
LinkBack URL
About LinkBacks
