Rear Clunking - Everything is tight
Results 1 to 15 of 21
Thread: Rear Clunking - Everything is tight
    FRESHMAN ROVER CapeCod's Avatar
    March 28th, 2015
    Boston
    235
    A few weeks back I had the rear Ace bar replaced on my 2010 RRS SC, as it was leaking pretty good. Since I got it back I have been getting an intermittent clunking from the rear. There is no rhyme or reason to it, but it tends to happen less over larger bumps and at higher speeds. Which confuses both me and the shop. When I am driving, especially in traffic, and there is even a slight uneven spot, the clunk will present itself. I have brought it back three times, and everything in the back is tight and without play. The noise is hollow in sound and sounds almost like a drum. Has anyone else ever run into this? Any ideas on what should be checked?
    The shop that replaced it is very good at what they do, and they specialize only on rovers.
    Santorini Black 2010 Range Rover Sport SC with Ebony Interior
    FORUM MODERATOR Brimill1234's Avatar
    January 14th, 2013
    Lucketts, VA
    1,205
    Re: Rear Clunking - Everything is tight
    Are your rear seatbelts in front of the seat or draped behind? I chased a random hollow sound for a while and realized my seat belts were behind the seat after folding them back up and were lightly tapping the interior panel. Sounded like it was coming from strut area when driving.
    2013 RRS HSE LUX Santorini black
    QuickSilver Exhaust
    20" Redbourne Nottinghams
    I am a professional so please use caution, I may have enjoyed a few cocktails when I told you to go ahead and try this at home...
    March 28th, 2015
    Boston
    235
    Quote Originally Posted by Brimill1234 View Post
    Good suggestion. I have had that before, so I know exactly what you mean. Unfortunately this is not the same noise. If my window is down, I can hear it outside of the vehicle.
    September 12th, 2007
    5,216
    Not sure about the disconnectable sway bar, but to remove the regular one I recall the body has to be separated from the frame...that a lot of stuff to move around, perhaps something didn't get tightened up?
    March 28th, 2015
    Boston
    235
    You are correct, the body does have to be lifted to access it, even with the Ace Bar. They spent hours checking everything yesterday. Every piece was secured and tight. It is quite frustrating.
    JUNIOR ROVER Canrover's Avatar
    December 15th, 2014
    Gloucester
    721
    Hey CC,
    Is the dealership doing this under the extended warranty coverage you bought a while back? Just wondering...
    "I know the voices aren't real but man do they ever come up with great ideas!" 2010 Range Rover Sport Supercharged, Santorini Black with ebony interior and Alcantera seats
    March 28th, 2015
    Boston
    235
    Yes, it was covered. I have been back three times, and they have not charged me for any of the follow-up visits. They seem baffled. Surprisingly after that initial nonsense with that warranty, they have been super easy to deal with oddly enough.
    Upon reading on other range rover models with the Ace system, it appears that the Ace Bar can create this problem. In a lot of cases, if they pull the fuse for the Ace System, the noise disappears. I want to try this, but have no idea which fuse goes to that system.
    December 15th, 2014
    Gloucester
    721
    Interesting...... Well, we have the same model and year so my fuse boxes are most likely the same as yours unless there is a Canadian version. The only difference that comes to mind is the heated windshield.
    What does ACE stand for in terms of the Ace Bar?
    As for the coverage, bravo!!!!! I'm glad it is paying off for you. Makes me consider getting one as well.
    March 28th, 2015
    Boston
    235
    Quote Originally Posted by Canrover View Post
    Yea, so the last 10 months the tally is up to $17k in work. $11k of that was covered by the warranty. Warranty cost $3800, so it has paid for itself three times over.
    ACE Stands for Active Cornering Enhancement.
    June 24th, 2012
    canada
    543
    Mine also makes that clunking sound every so often and seems more prevalent when it's cold outside. I think it's the ace system doing its thing.
    Just a wild guess, but I also think the tight new bushings add to it because they resist the twist of the bar.
    I also think we become more aware of sounds that should not be there after changing out the bushings.
    2009 RRS S/C
    March 28th, 2015
    Boston
    235
    Quote Originally Posted by arby View Post
    This clunking is LOUD.. This is not normal operation at all. I had someone at a stop light tell me to have my rear suspension checked that something is broken.
    June 24th, 2012
    canada
    543
    Not at home , so can't read my manual for fuse location. Tried a bit of a google search. Maybe the system needs bleeding.
    http://www.lrrforums.com/showthread....bleeding/page3
    2009 RRS S/C
    March 28th, 2015
    Boston
    235
    This is great information. Thanks so much!
    March 11th, 2014
    212
    Not sure if there are sway bar links between end of ace bar and axle - I assume those were replaced ? WEre they new or rebuilt ? We're bushings also replaced ? On conventional system clunking often comes from worn bushings or worn joints in the links. If Cluncking started after ace bar replace - perhaps you have defective unit and need it replaced again ? Others on these forums got clunck from e-park brake - loose springs or something like that inside drum .. Was that removed or adjusted during ace job ?
    March 28th, 2015
    Boston
    235
    Quote Originally Posted by Alpaca View Post
    When the rear ACE bar was replaced, the bushings were also replaced. The links did not need replacement, as they were tight and not sloppy.
    As a diagnostic measure, I am curious to find the fuse for the ACE system so I can pull it and see if it does away with the clunking. From what I am reading on other forums, pulling the fuse almost always does away with the noise. If it does silence the clunking, I will be stuck to figure out what exactly is causing the clunking within the system.
  1. Clunking noise rear Diff/ Suspension
    By BlueGillette in forum Range Rover Sport / L320
    Last Post: September 7th, 2014, 11:55 PM
  2. How Tight Should My Nuts Be??? :)
    By big-t in forum Range Rover Mark II / P38
    Last Post: July 19th, 2009, 03:20 PM
  3. Rear end Clunking
    By erastide in forum Range Rover Mark II / P38
    Last Post: February 23rd, 2008, 08:23 AM
  4. Help....the dreaded clunking noise in the rear...
    By fallingat120mph in forum Range Rover Classic
    Last Post: March 4th, 2007, 04:41 AM
  5. Shocks how tight?
    By googsy1 in forum Range Rover Mark II / P38
    Last Post: November 1st, 2005, 10:24 AM
