Rear Clunking - Everything is tight - Page 2
Results 16 to 21 of 21
Thread: Rear Clunking - Everything is tight
    SOPHOMORE ROVER CapeCod's Avatar
    March 28th, 2015
    Boston
    252
    Re: Rear Clunking - Everything is tight
    Would anyone know which fuse I should pull in my 2010 RRS SC to deactivate the ACE system?
    2010 Range Rover Sport SC - Santorini Black with Ebony Interior (sold)
    2017 Range Rover Sport HSE - Corris Grey with Ebony/Cirrus Interior
    March 28th, 2015
    Boston
    252
    Just wanted to send an update for future people searching the forum. The problem was the stabilizer bar links. They were not worn too badly, but under certain angles/speeds/bumps, they would be noisy. When the truck was lifted everything appeared completely tight. It was discovered after a technician got under the truck while it was on the ground, and a couple guys rocked the truck back and forth.
    Happy to report that everything is nice and quiet!
    June 24th, 2012
    canada
    563
    Excellent, thanks for reporting back. I have a new set of end links which I have not bothered to put on, because when I had them loose for bushing replacement they felt tight as old heck. I will replace mine when it warms up outside.
    2009 RRS S/C
    June 24th, 2012
    canada
    563
    Crossed my mind today while out in my RR that what probably happened was that one of the end links were not tightened properly. It happened to me after changing the front bushings. A couple of days later a clunk started that got progressively louder. Since I already had new end links, I jacked up the front wheel to begin repalcing the links. To my surprise the link nut was not tight. Not sure how that happened, but easy to see that it could since you need to lock the knuckle bolt with a Torx bit. The knuckles themselves are in some kind of hard urethane and hard to see that they could make a loud enough sound that another driver would comment on it, but a loose nut does cause a loud metal to metal knock.
    I can see how it happens. These guys like myself are using impact guns. When you remove the nut it becomes apparent that the bolt is spinning and needs to be held, but later when buttoning everything up, you use the gun and forget that the bolt needs to be restrained.
    2009 RRS S/C
    FRESHMAN ROVER msh26's Avatar
    October 19th, 2006
    Del Mar, CA
    101
    Quote Originally Posted by CapeCod View Post
    Hey CapeCod, I think I might have the same thing happening on my '08. Did you have to replace the stabilizer bar links or just tighten them up? Thank you for your response in advance!
  8. #21
    March 28th, 2015
    Boston
    252
    Quote Originally Posted by msh26 View Post
    Replaced them
  1. Clunking noise rear Diff/ Suspension
    By BlueGillette in forum Range Rover Sport / L320
    Last Post: September 7th, 2014, 10:55 PM
  2. How Tight Should My Nuts Be??? :)
    By big-t in forum Range Rover Mark II / P38
    Last Post: July 19th, 2009, 02:20 PM
  3. Rear end Clunking
    By erastide in forum Range Rover Mark II / P38
    Last Post: February 23rd, 2008, 07:23 AM
  4. Help....the dreaded clunking noise in the rear...
    By fallingat120mph in forum Range Rover Classic
    Last Post: March 4th, 2007, 03:41 AM
  5. Shocks how tight?
    By googsy1 in forum Range Rover Mark II / P38
    Last Post: November 1st, 2005, 09:24 AM
