S/C - engine fault
Results 1 to 9 of 9
Thread: S/C - engine fault
    January 8th, 2008
    Austin, Texas
    13
    S/C - engine fault
    over Easter my S/C sport started showing engine fault warning and would only go 70 with the pedal to the floor at 6,000 RPMs. I was barely able to make it to the next town, because I was getting 3 mpgs. Around town the truck had no problem but as soon as I get it on the highway for an hour or more this happens.
    Anyone had this problem or know of anyone that has?
    2007 Range Rover Sport Supercharged
    2006 Range Rover Supercharged HSE
    11,027
    I don't own a Supercharged so I cannot be of much help I'm afraid, but my first guess would be a bad MAF sensor, of course. There is also a S/C specific TSB that may be related, it affects MY06 and some 07s:
    NASF TSB #LTB00041, Rev 2
    Reduced Power Under Load
    Possible DTC P0096 and/or P2601 Stored
    AFFECTED VEHICLE RANGE:
    Range Rover (LM) Supercharged 6A198058 to 7A261419
    Range Rover Sport (LS) Supercharged 6A901924 to 7A109767
    CONDITION SUMMARY:
    REDUCED POWER OR MISFIRE AT HIGH ENGINE LOADS
    Situation: The customer may complain of reduced power and or a misfire at high engine loads and road speeds, with the possibility of Diagnostic Trouble Codes (DTC) P0096 and/or P2601 stored. The electrical harness power supply and ground for the auxiliary coolant pump may be cross connected in connector C3006. The pump will run backwards causing the Engine Control Module (ECM) to reduce power to prevent damage because the pump flow is low. The auxiliary coolant pump will be degraded under these conditions.
    Action: Should a customer express concern, modify the wiring at connector C3006 to the correct positions:
    RR Sport Range Rover
    • Cavity 1 connected to "-" pump connection Black (B) Brown (N)
    • Cavity 2 connected to "+" pump connection Brown / Purple (NP) Red / White (RW)
    Install a new supercharger coolant pump as part of the repair if either the fault codes or the incorrect wiring is discovered following the Repair Procedure outlined below.
    FWIW, I experienced an Engine Fault once before on my 06 HSE. I was doing some spirited mountain road driving on my way from home to Big Bear here on the local mountains. Suddenly, right in the middle of nowhere the engine fault light came on and the car slowed down to a crawl and kicked down to 2nd or 3rd gear, no matter how hard I would punch the gas pedal. I pulled over to the side of the road and killed the engine (sweating profusely since there was no cellular phone signal there), waited a couple of minutes and restarted the car. The problem was gone. I always assumed that the relatively quick change in air pressure / altitude had temporarily tricked the MAF sensor into thinking there was a problem with the air intake. I never experienced a similar issue since.
    April 24th, 2005
    Springfield, Massachusetts, USA
    215
    Re: S/C - engine fault
    I actually wrote a blog post on this, which you can read here:
    http://robisonservice.blogspot.com/2010 ... -stop.html
    It seems like some number of these vehicles left the factory with the wrong engine software. Then, when a dealer does a routine service update and the correct software is fitted, this problem appears. Curious . . .
    The fix: Correct engine management software, a new aux coolant pump, and reversed wiring.
    Right now, this is customer pay work. But I wonder if there will be a recall. It's hard explaining why a customer should buy a $200 pump and a few hours of labor to fix a production problem. There's not much way to turn backwards wiring into a maintenance issue.
    October 22nd, 2012
    Charleston SC
    Can anyone point me to the approximate location of this wiring harness connection and/or the pump location so I can rewire myself? LR has refused to fix this factory defect out of warranty.
    TIA
    July 17th, 2013
    Columbus Ohio
    Replacing the pump is pretty straight forward but does anyone have instructions on how to do the rewire?
    11,027
    You may need a "Terminal extraction tool" as indicated in the TSB (someone who actually did the rewire may chime in with his/her direct experience... Just going by what the TSB states.) You can find actual copy of the TSB here, it explains the rewiring procedure more clearly than the pasted text above: https://app.box.com/rrs/1/651822509/6145231159/1
    July 22nd, 2014
    Los Angeles
    I currently have this problem on my 2008 RRS S/C. My independent mechanic read this thread, and we will start with updating the computer software and then changing the water pump. I will report back on progress. My mechanic says the computer should still be under warranty for 8 years.
    I've had problems with the RRS stalling after the first start in the morning (even though it is not very cold in L.A.) and stalling after the first few blocks when I have to brake for a stop sign. I left the car and the Land Rover dealer (Pasadena, CA) for several days, but they could not find any problems.
    July 22nd, 2014
    Los Angeles
    Late update: Changing the water pump solved the issue of the RRS stalling under load, and it seems to have improved the stalling that happens when the car is first started in the morning. I mentioned this to my new non-dealer, but factory trained, mechanic, and he said he has dealt with this dozens of times.
    FRESHMAN ROVER RobWCanada's Avatar
    January 5th, 2015
    Canada
    12
    Hey all, I have this issue. But my wires seemed to be wired correctly. That said, the wire was so tight going to the pump that it was cut half way through. I took apart the connector and cut the wire off and soldered it to the connector and put it all back together.
    I still got the "Reduced Engine Performance" message. No check engine light, but a P2601 code.
    By the way DO NOT "Read Codes" with an ELM 327 wifi OBDII scanner. It lights up the dash like a Christmas tree and throws every code known, dash also said "Parking Brake Fault". And then shuts off the motor, and when slow enough shuts off the power steering. Not cool...I was panicking. But luckily I had my OBDII scanner and I cleared all codes on the side of the highway and cleared all the codes and I was on my way again.
    Anyway, to my point, pretty sure the pump has been stressed gotta either replace the pump or see if the fuse is blown...wherever that is.
    ALSO, someone was aggravated how difficult it was to replace the pump. I have a tip. If you just remove the front grill, and the driver's side headlamp (very easy, held on with 3 #3 philips and a massive connector...just clips off) you have direct access to the pump...it's right there...really easy. And you have direct access to the bracket bolt too.
    ____________________________
    Rob - Toronto, Canada
    2008 Range Rover Westminster
    L322 - Supercharged
  1. Engine System Fault
    By bbdesoleil in forum Range Rover Mark III / L322
    Last Post: October 21st, 2011, 02:10 PM
  2. Engine System Fault
    By calvin84 in forum Range Rover Sport / L320
    Last Post: October 24th, 2010, 10:54 PM
  3. Engine System Fault
    Last Post: October 23rd, 2007, 09:27 AM
  4. Clearing a Check Engine fault
    By RoverOH in forum Range Rover Mark II / P38
    Last Post: August 13th, 2006, 02:36 AM
  5. TSB - Engine System Fault (S/C only)
    Last Post: July 10th, 2006, 12:09 AM
