Rough Estimate: How much to rewire engine compartment???
Results 1 to 3 of 3
Thread: Rough Estimate: How much to rewire engine compartment???
    October 27th, 2006
    montclair, NJ
    56
    Hey guys,
    I have a 1993 RR LWB with 170,000 miles ,and the engine compartment is a little shaggy.
    Much of the wiring under the hood is frayed/corroded/worn/dirty.
    I know this may be completely unanswerable, but does anyone have a "guesstimate" as to how much it would be to replace all/most of the wiring under the hood?
    Again.....its a shot in the dark, but let me know what you think.
    1993 "roman bronze" RR LWB
    http://www.hollerwildrose.com
    July 24th, 2005
    Chicago, IL
    323
    It cost me 1,000 USD to get a burned out wire sorted- it shorted out from passenger footwell to the fuse box-whole dash was supposedly taken apart.
    March 12th, 2006
    CT, USA
    326
    There are two different harnesses under the bonnet, the EFI harness and the main harness. The EFI harness extends from the injectors to the O2 sensors and various other sensors back through the bulkhead, along the left side of the passenger console to the ECU under the passenger seat. It is a faily straight forward job requiring the removal of some of the top end of the motor to gain proper access. I would imagine that parts like the blower motor under the psssenger side of the dash might have to be removed as well. I'm guessing but I would have to think you are taking about at least three or four hours for that harness.
    The main harness runs along both inner fenders and has wiring for everything from the fog lights to the ABS pump, condensor fans, ect. It would be an absolute nightmare to replace the entire main harness as the dash would need to be completely removed. If you were to splice in new lines from the bulkhead forward it would be a far more doable job. Nevertheless, you would have a few hours of labor there as well.
  1. Engine Compartment lighting
    By aernan in forum Range Rover Mark II / P38
    Last Post: October 12th, 2008, 01:34 AM
  2. Cleaning Engine Compartment
    By CASANOVA in forum Range Rover Sport / L320
    Last Post: June 26th, 2007, 05:23 PM
  3. Engine Compartment Fuse Box
    By ainiguez in forum Range Rover Mark II / P38
    Last Post: February 23rd, 2007, 05:11 PM
  4. Hot engine compartment
    By Max2008 in forum Range Rover Classic
    Last Post: August 8th, 2006, 06:50 AM
  5. Cleaning the engine compartment? Yea - Nea
    By agood1 in forum Range Rover Mark II / P38
    Last Post: December 2nd, 2005, 02:01 PM
