90 RRC dash
Results 1 to 3 of 3
Thread: 90 RRC dash
    July 18th, 2010
    Las Vegas Nevada USA
    70
    90 RRC dash
    Guys, what should ther voltage be on the White with Slate wire from the back of the alternator? #142 on the schematics. I've got seven volts and none of my gauges work. Speedo has been flaky since day one but since the alternator change the Tach, fuel gauge and temp are all worthless. Should this be a regulated twelve volts?
    July 18th, 2010
    70
    Re: 90 RRC dash
    Made some progress today. I took out the new alternator as the battery light started shining. The fresh new POS only lasted a couple months. I put the old one back in, bad bearing and all and now I have tachometer again. Beyond that I dug into the binnacle and found a loose connection on the blue wire for the speedo being loose. 20 years ago the dealer wanted $2500 to repair that speedo and finally , while driving, I found that loose wire! I think the screw has backed off enough over the years to make it noticable.
    In addition, I came across the ORIGINAL alternator from 1990 on the shelf so I think I'll take that down to a rebuilder so it'll be availble when the wonderful Magneti Marrelli second alternator finally stops grinding.
    February 6th, 2009
    Penn Hills, Pennsylvania
    317
    Re: 90 RRC dash
    many of us have had bad experiences with after market alternators , my first finally cost me over $800 . finally had good luck with Denso brand . i might have paid $250 but it never gave me a problem . after bying many parts cars i have a few spares .
  1. Do I have to take out the dash?
    By benji in forum Range Rover Mark II / P38
    Last Post: October 22nd, 2011, 01:10 AM
  2. Dash Kit Yes or NO?
    By lear60man in forum Range Rover Mark III / L322
    Last Post: March 28th, 2010, 11:26 AM
  3. dash clock
    By andyaa in forum Range Rover Mark II / P38
    Last Post: November 19th, 2009, 07:08 PM
  4. dash dead
    By 94cntylwbfl in forum Range Rover Classic
    Last Post: October 13th, 2009, 08:01 AM
  5. Dash Pad????
    By hew1975 in forum Range Rover Sport / L320
    Last Post: October 8th, 2008, 04:12 PM
