blinkers not working
Results 1 to 3 of 3
Thread: blinkers not working
    November 8th, 2010
    Sacramento, CA
    72
    I did a quick forum search but couldnt find details. None of my blinkers work - front, rear, left nor right. They used to. I hear the ticking when I turn them on and although its the wrong one and has been the wrong one, the trailer looking light blinks on my instrument panel.
    The fuse in the panel checks out but on the posts I found, there are relays elsewhere. Anybody know where those are? ill do a rave search if I can find my disk, but given the importance of these I figured id post as well. Thanks!
    Just trying to understand all this Rangie talk and tech....hoping to turn from noob to experienced.
    '89 Range Rover - Ignition: MSD 6A, Kingsbourne 8mm Wires, Pro Comp +2 shocks, Med Duty OME Springs, 245/75 16 GY Duratracs
    '90 Audi 200 Quattro - Turbo
    January 18th, 2010
    Wisconsin, USA
    244
    Re: blinkers not working
    In my 89 the relay was under the steering column. Mine got progressively worse until they stopped working. I disassembled the relay and there were cracks in the solder on the circuit board. 5 minutes of soldering later, it works like a champ and for the past 18 months have had no indicator problems!
    1989 RRC
    2001 RR HSE
    November 8th, 2010
    Sacramento, CA
    72
    I dug around under there - I saw many relays. I could not figure out which one was the correct one - any ideas/pictures/descriptions or diagrams I need to study? My hazards don't work either....
  1. Funky Indicators / Blinkers
    By james in forum Range Rover Classic
    Last Post: May 1st, 2010, 05:11 PM
  2. 93 LWB blinkers will not work
    By 38wolek in forum Range Rover Classic
    Last Post: December 1st, 2009, 11:26 AM
  3. 03 Rover - Electrical / Nav / Stereo / Blinkers / WTF
    By alindquist in forum Range Rover Mark III / L322
    Last Post: May 3rd, 2009, 06:11 PM
  4. Steering Wheel not working, TILT + TELESCOPE not working
    By charly_talon in forum Range Rover Mark III / L322
    Last Post: September 19th, 2008, 03:50 AM
  5. PLEASE HELP! - inop blinkers
    By Mark in forum Range Rover Classic
    Last Post: November 6th, 2005, 01:02 PM
