Can anyone shed some light please on a way-ward connector. I've spent the last 2 days trying to find where a round shape two pin plug connects home onto the 13-61-005 transfer case of my 1990 era RR Classic chassis. I've searched on here and Googled plus checked through my service manuals but I am real stuck. I have hunted down pictures of the early model transfer case but i just cannot find any reference to it. Someone suggested it's for a temp sensor because this is a 13-61-005 case running with a 3.9V8.
My thought here is it might be the topside of the Transfer Case is so piled with dried mud that i can't locate the connection place but i have never seen this model case out so i simply don't know.
The concern is this is some kind of status the ECU should be receiving and might be the cause of other issues.
I have worked out there's a loom of total 6 wires that run to the Transfer case and the 4HP-22 Transmission.
The transmission has 4 wires: green (common), green-brown, black-orange and black (common) which provides for Neutral/Start inhibit.
The Transfer Case has a connection point behind the handbrake drum using 2 wires black-grey (joins to the Transmission black common) and a black-purple which is possibly the Diff Lock warning.
The ''way-ward'' is a round female plug connector with a YELLOW and GREEN (the green joins to the Trans green-common).
I hate describing a circuit on just the colours of wires but what i'd truly appreciate is if anyone has a better manual than my CD 1990 RR Workshop Manual. Even a couple of clear pics of a 13-61-005 and it's electrical connections would be perfect.
As always, TIA Pete .... in New Zealand
LinkBack URL
About LinkBacks
