Heater/AC issue
Results 1 to 13 of 13
Thread: Heater/AC issue
    December 12th, 2011
    United States
    8
    Heater/AC issue
    Hi
    I've got an 89 RRC and the blower only works on the AC setting. I get all 3 speeds. However when the selector is on any of the other settings (recirc, fresh air, etc), the blower does not work at all. I only hear a slight 'whirring' noise that ramps up a little with each speed, but no air comes through the vents.
    I'm assuming that the blower motor works, since it works great on AC. I'm also assuming that the resistor is working since I do get all 3 speeds.
    Therefore I'm guessing that the selector switch is bad? Is that the right assumption, or is there anything else I am missing? I'm having trouble locating that switch since I don't know the exact name of it. I only find the blower switch at stores, which I don't believe I need.
    Thanks in advance.
    February 6th, 2009
    Penn Hills, Pennsylvania
    346
    Re: Heater/AC issue
    there are seperate motors for ac and heater. ac motors are under dash on pass side , heater is inside dash behind heater controls. go to atlantic british homepage tech info blower motor for pics of motor and replacement inst.
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    I didn't see any separate blower motors for AC and heater. And isn't the heater core on the pass side behind the dash?
    23,529
    Re: Heater/AC issue
    Heater core is dead center of the rig behind the climate controls. See the pages on Atlantic British referenced above.
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    Thanks for responding, everyone.
    Ok, so I looked at this tutorial: http://www.roverparts.com/Instruction%20Photos/Instructions-HeaterBMK-8844.pdf
    P
    age 9 shoes the heater core on the passenger side. Page 19 shows the blower in the middle of the dash. Again, only one blower is shown for this entire tutorial, so I'm a little confused. I'm really hoping I don't have to do that much work though to fix the heater! :-O
    23,529
    Re: Heater/AC issue
    Now I am confused as well! I have a feeling i have P38 on the brain and am mixing up my various projects over the years.
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    LOL, Ok, now that makes a little sense. I did a quick search on Atlantic British and I see both a blower motor, and a blower motor right-side for the P38.
    So, is it safe to say the RRC (1989) has just one blower motor? And, does that mean mine works, and I just need to replace the switch? (the blower works, but only when selected for AC) Or....?
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    BUMP
    (it's cold!)
    23,529
    Re: Heater/AC issue
    If your cold use the AC on hot since the fan works in that mode.
    February 6th, 2009
    346
    Re: Heater/AC issue
    its a lot of work but first test resistor , unlikely but this may be your problem but is going to be replaced anyway so it doesnt hurt to check.
    December 26th, 2011
    salt lake city
    Re: Heater/AC issue
    I found this out the other day. Your dash vents will never blow hot air. Only defrost and foot will blow heat. Not really sure if this is what you were talking about but i found it interesting.
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    Ah, ok. Then that makes a LOT more sense and definitely narrows the troubleshooting. Thanks!
    I will definitely look at the resister first thing. If not that, could it be the blower then?
    December 12th, 2011
    United States
    8
    Re: Heater/AC issue
    Update: There is a dull clicking noise that comes from somewhere in the dash, I believe. This only happens when I turn the wheel to the left (while moving) and with the fan turned on to any speed. At first I thought it was a steering issue until I realized it does not occur when the fan speed it off. Any ideas what that noise is? It is erratic, but gets faster the faster I'm moving. It doesn't appear to come from under the hood or underneath.
    I'm supposed to go to Tahoe this weekend for new year's eve, but it's going to suck without a heater.
  1. Blend flaps / Heater Box / Heater core /Dash -Lots of photos
    By lui2001 in forum Range Rover Mark II / P38
    Last Post: December 11th, 2013, 05:53 AM
  2. Tailgate issue, and pesky passenger door issue...
    By CHRISDANIELS33 in forum Range Rover Mark II / P38
    Last Post: May 24th, 2010, 12:06 PM
  3. Different heater issue, one speed then huge draw?
    By GrFa in forum Range Rover Classic
    Last Post: January 14th, 2010, 06:59 AM
  4. Ignition issue or on board computer issue
    By cackatron in forum Range Rover Mark III / L322
    Last Post: October 21st, 2009, 07:00 AM
  5. Heater core O-rings. Heater pipe misalignment? No. read on.
    By Brett San Diego in forum Range Rover Mark II / P38
    Last Post: June 24th, 2008, 08:31 AM
