ABS to non ABS?
Results 1 to 5 of 5
Thread: ABS to non ABS?
    November 1st, 2009
    w. HOLLYWOOD CA.
    265
    ABS to non ABS?
    hey guys i am sure u spoke about this before, but since i am new to rovers i dont have any info, is it posible to convert abs 1990 model to be non abs?
    tnx
    Eric
    few REAL HUMMER H1s
    few REAL RANGE ROVERs
    ZO6, and DB9
    http://www.youtube.com/watch?v=8KEqxgyULTg
    July 18th, 2010
    Las Vegas Nevada USA
    182
    Re: ABS to non ABS?
    I assume you want to do that because another POS pump motor has burnt itself to oblivion? I've had one original and two Ebay specials so far and at the moment the brakes work. The ABS light never goes out but the brakes work.
    I too will be interested in knowledgable responses.
    Thanx in advance
    1990 RRC, 1992 RRC
    23,131
    Re: ABS to non ABS?
    I know of atleast two people that have used older model booster and master cylinder to ditch their ABS. One gent had flex lines made up to screw onto the existing brake lines and up to the "new" master cylinder.
    March 29th, 2009
    Queens, NY
    67
    Re: ABS to non ABS?
    It is possible and many have done it. I think you can use all the bits form an 87 and Defender calipers. I did have a PDF on how to do it and i will try to dig it up for you.
    ______________________________
    1991 Range Rover Great Divide #372
    February 6th, 2009
    Penn Hills, Pennsylvania
    346
    Re: ABS to non ABS?
    Theres a long post on this if you do a search. I have a 93 w abs and a 92 without, seems like an easy swap except for conversion from dual lines to rear to single line. there is a junction adapter on pass fender well that does this, this setup is common on newer Discos so the part is available from dealer. I've seen vaccume booster and master cyl for $250 each rebuilt on ebay. There is a big difference in braking power, abs brakes have much more solid feel and better ease of operation compared to master cyl setup.
