IACV/ Stepper Motor / Vacuum leak help
Results 1 to 4 of 4
Thread: IACV/ Stepper Motor / Vacuum leak help
    FRESHMAN ROVER signalMTB's Avatar
    October 25th, 2012
    Chattanooga, TN USA
    113
    My dad's '95 RRC has a high idle at start up, throws the '48' stepper motor code. I've cleaned the stepper motor (IACV) and MAF plug. New IACV is $160 so not super interested in just trying a new one. Might be a vacuum leak...never traced or replaced or diagnosed a vacuum leak before. Any thoughts or help?
    1994 RRC LWB
    2005 RR L322 HSE
    1997 NAS D90 SW
    1988 951S silberosa
    3 prior '95 RRCs, of which I really miss one of them
    July 13th, 2008
    New York, USA
    223
    Re: IACV/ Stepper Motor / Vacuum leak help
    As a test, you should switch the IACV with the one from your LWB or NAS.
    Vacuum leaks are generally found via a smoke test. You can also use some starter fluid, or carb and choke cleaner, around where you think the leak is while the engine is running. Lots of information about alternative testing with a google search.
    Even simpler, check to make sure that non of the vacuum lines have just fallen off.
    1990 Range Rover - http://www.defendersource.com/forum/...irs-60356.html
    1995 Range Rover LWB - daily driver
    February 18th, 2008
    Portland, Maine
    64
    Stepper from a Chevy Astro van will work & you can get it at NAPA. Don't remember which year so do a search. I want to say late '80s.
    Have a read here..... Deals on Stepper Motors?
    Kevin
    88 RRC "Audrey"
    October 25th, 2012
    Chattanooga, TN USA
    113
    Quote Originally Posted by rangerover View Post
    ok thanks, at this point I'm trying to locate a vac hose diagram. Ordered a IACV, due in tomorrow. $45 at autozone
    1994 RRC LWB
    2005 RR L322 HSE
    1997 NAS D90 SW
    1988 951S silberosa
  1. Stepper motor
    By CrisRange96 in forum Range Rover Classic
    Last Post: October 16th, 2015, 07:47 AM
  2. Stepper motor testing?
    By nakedbarra in forum Range Rover Classic
    Last Post: August 24th, 2007, 07:47 PM
  3. Stepper Motor testing?
    By nakedbarra in forum Range Rover Mark II / P38
    Last Post: January 9th, 2007, 09:06 PM
  4. STEPPER MOTOR WASHERS?
    By daway in forum Range Rover Classic
    Last Post: December 4th, 2006, 09:59 PM
  5. Stepper Motor (IACV)
    By yrunvus in forum Range Rover Mark II / P38
    Last Post: October 28th, 2006, 08:56 AM
