Center Console Dead, would Softdash console fit?
Results 1 to 10 of 10
Thread: Center Console Dead, would Softdash console fit?
    FRESHMAN ROVER miggit's Avatar
    July 12th, 2014
    Milton Keynes UK
    30
    I'm going to throw this idea out there!!
    I have a very, very, broken center console and I have discovered that they are rare in complete form, so what to do?
    I did stumble on a chap who was making bomb proof consoles out of half a tree, but he's stopped posting updates 7 years ago.. so I'll assume that he's given up, or got too many splinters
    Not having easy access to a workshop, I'm keen to find an alternative replacement, rather than go down the hammer and nails route...... So I've been looking at what is available for the RRC... and there are a few softdash consoles available. Having studied these consoles I have become aware that they bare more than a striking resemblance to the console in a Discovery 2.... LR been raiding the parts bins?
    Now I realise that the later consoles have the plastic lower part that holds the radio on mine, included in the console, and there is a major difference at the dash end, BUT, from what I can make out the earlier console finishes just in front of the gear levers and pokes under the radio pod... So could I take a saw to a later console and get it to fit? Has anyone tried this?
    Or would a later console just fit if I do away with the radio... as there are plans to move this anyway!
    June 11th, 2016
    northern va 22003
    314
    Re: Center Console Dead, would Softdash console fit?
    depends on the year of your truck, pre 95 you will have lots of cutting and hacking to fit a discovery style dash. pre 95 dash is actually a piece of metal covered by plastic, also the hvac is different between the pre 95 and later.
    any way you go, good luck.
    July 12th, 2014
    Milton Keynes UK
    30
    Well at least you haven't said NO!! I'm not looking to change the whole dash, just the middle bit between the seats! I suppose the best thing is to cop hold of a cheap one and see how it goes!
    June 11th, 2016
    northern va 22003
    314
    Quote Originally Posted by miggit View Post
    I restore rovers for a living, this include modifications. to me "NO", "NOT POSSIBLE" or "CAN'T BE DONE" simply do not exist.
    if the willingness, time, motivation, idea and money are there then why not do it?
    July 12th, 2014
    Milton Keynes UK
    30
    While I don't restore LR products for a living, I do believe that if something can be improved, and is life changing or cost effective then it should be done! Like the TV Sat Nav Stereo that I'll be fitting.. Why? cos I miss the reversing camera that I got used to in the L322... Plus towing for a living I can hook up to half a dozen trailers in a day, and more if they are being sited at an event.. my record is 150 trailers in a day , but they didn't go very far!! Jumping in and out to get the hitch lined up is a real pain, so a camera just makes it easy.. and safer for the bumper!
    I was even toying with the idea of a Discovery 3/4 or RRS console... you can get a fridge for them!
    August 29th, 2016
    Albuquerque, US
    38
    Disco I and II consoles are a perfect fit. No modification necessary other than widening the shifter opening slightly. Just use your old one as a template. No need to modify the TS shifter opening.. I grabbed the seat switches from the disco and wired them into my 95 classic classic and got rid of the pods.
    July 12th, 2014
    Milton Keynes UK
    30
    Sweet! that is good news, thanks
    ​Range Rover Classic 1988 Fueled by the Devil (2.4 VM Diesel)
    August 29th, 2016
    Albuquerque, US
    38
    I meant TC shifter. The disco I and II center dash trim bezel also fits fine with just some trimming of the upper lip of the disco bezel. And yes the disco I and II dash assembly is direct swap also with the 95 classic. I have a Disco II dash and center console in my 95 County LWB. The extra switch positions in the instrument cluster housing of the disco are great spots for auxillary switches for off road lights etc, because all of the switches from the disco that go there are in the center dash bezel of the classic so you have all those blank spots for whatever you want.
    FRESHMAN ROVER slohybrid's Avatar
    April 6th, 2012
    San Luis Obispo, CA
    18
    The way I read this is you have a pre 95 Range Rover wanting to install a 95 RRC console/ D1 style?? If so it will fit however where it meets the dash in front of the transfer box shifter it will need modification as the pre 95 slips under the dash whereas the 95 on/D1 follows the trans tunnel and hides further back under the dash. If I were you I would try and re-inforce your existing cubby box with metal a common practice.. The later consoles are entirely made of plastic and become brittle and also break. hope this helps.
    04 Range Rover
    95 4.6 Range Rover 25th anniversary
    94 LWB 4.6 offroader
    87 RRC
    05 Jetta TDi wagon
    83 Rabbit Gti
    80 RX7
    17 Volvo XC 60
    July 12th, 2014
    Milton Keynes UK
    30
    I'm beginning to feel that it might be better to just do away with it altogether and relocate the window switches..
    My console is in 8 parts with bits missing.. a simple reinforcing job would result in a 95% metal box!!
    But you do have a valid point that a replacement even if it was from the last ever D2, is still going to be at least 15 years old, still going to be badly made, and still use self destructing plastic
  1. RRC Softdash - AC stinks, center console removal, fan blowr
    By Sadn3ss in forum Range Rover Classic
    Last Post: December 29th, 2015, 07:11 AM
  2. Center Console
    By HSOLO in forum Range Rover Mark III / L322
    Last Post: November 18th, 2010, 09:39 AM
  3. Center Console NON-op? (I Need Help)
    By mazenkh21 in forum Range Rover Mark II / P38
    Last Post: March 17th, 2010, 08:52 PM
  4. Dead Center Console!?
    By Boaz in forum Range Rover Sport / L320
    Last Post: March 13th, 2007, 07:53 PM
  5. Center Console
    By auburnrover in forum Range Rover Classic
    Last Post: March 29th, 2006, 05:02 PM
