Auto gearbox
Results 1 to 2 of 2
Thread: Auto gearbox
    February 10th, 2017
    Suffolk
    Auto gearbox
    Hi guys, newbie to here so forgive me if I ask any daft questions!! Got a 3.5 classic and I'm after changing the gearbox fluid and filter as gearbox has a slight whine, not saying it will solve the problem but just peice of mind that's it's been done! I was told atf for the box which is red isn't it? When I checked mine on the stick there is no hint of red to the fluid, just clear oil, so I wondered if the box has the wrong fluid in?? Also the only other thing I'm not sure of is that when I check the level of the fluid following the correct procedure, the level on the stick is over full and doesn't drop down after going through all gears? Any advice would be great, thanks
    FRESHMAN ROVER miggit's Avatar
    July 12th, 2014
    Milton Keynes UK
    136
    Re: Auto gearbox
    I believe that proper ZF gearbox fluid is straw colour..... red is Dexron type GM fluid... so it really depends on what gearbox is fitted to your ride...
  1. Auto Gearbox fluid replacement on L322 TD6 or M57 and GM gearbox
    By L322_expert in forum Range Rover Mark III / L322
    Last Post: May 28th, 2013, 06:03 AM
  2. Auto Gearbox
    By stormin in forum Range Rover Mark III / L322
    Last Post: November 8th, 2011, 04:22 AM
  3. My Auto Gearbox...
    By wills in forum Range Rover Mark II / P38
    Last Post: November 19th, 2008, 07:47 PM
  4. Auto gearbox cooler
    By dave3d in forum Range Rover Mark II / P38
    Last Post: January 26th, 2008, 09:06 AM
