no start, no fuel from regulator
Results 1 to 5 of 5
Thread: no start, no fuel from regulator
    FRESHMAN ROVER Ranger SAR's Avatar
    November 16th, 2016
    California
    44
    Hi team
    I replaced the fuel filter and now have a no start issue. I have spark and injector pulse. Pump whines with key on. I don't have a fuel pressure test kit yet, but I find fuel by disconnecting the filter and checking fuel line at rail. However, no fuel in return line. Pressure regulator won't hold vacuum, but no fuel leaking through diaphragm.
    What gives?
    1987 Range Rover 3.5
    July 13th, 2008
    New York, USA
    233
    Re: no start, no fuel from regulator
    Are you sure you put the fuel filter on correctly and not backwards?
    1990 Range Rover - http://www.defendersource.com/forum/...irs-60356.html
    1995 Range Rover LWB - daily driver
    November 16th, 2016
    California
    44
    Absolutely, flow arrow is clear.
    This is madness. Is there any way to "presurize" the system besides cranking it for 6-10 seconds? I didn't depressurize the system by stalling it, I just dealt with spill by catching gasoline in a jar - this is the only thing I can figure may have done damage.
    I will update when I get my hands on a fuel pressure test kit.
    December 12th, 2015
    Milton, Ga
    61
    Try reinstalling the old filter. The new one could have a defect? Not sure how this could be possible; however, the new filter is the only variable that has changed.
    November 16th, 2016
    California
    44
    Locettc's advise was good, but not related to the filter. It made me thing about other recent changes. When I replaced my head gaskets I also put on new plugs and wires. While my test light showed spark, my multimeter showed very low voltage coming from the coil. I had installed resistor plugs and suppression wires. I see elsewhere this is not recommended.
    I traced my no start issue to a bad coil. I will be changing the plugs too, but I will keep the wires.
    Fuel pressure tested good.
  1. Fuel regulator or injectors?
    By BK177V in forum Range Rover Mark II / P38
    Last Post: April 16th, 2015, 07:57 AM
  2. 89 - Fuel Pressure Regulator
    By cmany0004 in forum Range Rover Classic
    Last Post: November 4th, 2014, 10:35 PM
  3. Fuel Regulator
    By Tyrnbiter in forum Range Rover Mark II / P38
    Last Post: August 3rd, 2009, 02:07 PM
  4. help with fuel pressure regulator
    By 1990classic in forum Range Rover Classic
    Last Post: August 15th, 2006, 11:08 AM
  5. Fuel pressure regulator
    By Rover Dan in forum Range Rover Classic
    Last Post: January 26th, 2006, 03:20 PM
