RRC 2.4 VM Diesel swap?
Results 1 to 5 of 5
Thread: RRC 2.4 VM Diesel swap?
    FRESHMAN ROVER miggit's Avatar
    July 12th, 2014
    Milton Keynes UK
    103
    Hi all, new to here.. sort of.. first post but been registered for a while...
    Just got shot of my 2003 TD6 L322 Vogue and I've just copped hold of an 88 RRC with a diesel lump.... I didn't pay a great deal of attention to the engine... from what I can see it's a VM and after a bit of panic searching on the web it's a 2.4.
    Now bearing in mind that I want to use it to tow heavy trailers (3 tons + major wind drag) I think that a replacement engine might be in order.. fast.. but funds are drained and time is of the essence.
    I do have plans to drop a Mercedes diesel with tweaked mechanical fuel pump and a 6 speed manual box (ECU free motoring, I'm sick of computer faults), BUT, that was going to be next year after I've made enough dosh. I was hoping to use the RRC this summer as a back up tow car to my rather worn out Mercedes ML.. So I need a quick cheap fix, a nut and bolt swap with a bit more power and less water consumption.
    Is a 200/300 TDi a straight swap, or am I into gearboxes and the like?
    November 23rd, 2010
    Utah
    1,969
    Re: RRC 2.4 VM Diesel swap?
    Welcome. I see you are from the land of concrete cows and loads of roundabouts. It was one of my favorite places while I stayed in the UK for a few years.
    Anyway, give us some details of your RRC. Does it have a manual transmission? Which transmission does it have. A 200TDI or a 300TDI should be a direct bolt in, depending on they did to put the VM diesel in.
    1993 RRC LWB 4.2L
    2000 Discovery Locked and Loaded
    July 12th, 2014
    Milton Keynes UK
    103
    From what I can tell it's got a short shifter LT77 and an LT230R transfer box!
    FRESHMAN ROVER roverwannabe's Avatar
    November 16th, 2007
    Nashville
    56
    Subscribed, I'm working on (planning stage) an OM 617 swap using an oversized turbo and a/w intercooler. Aiming for 150-ish HP with zero electrical needed once running.
    If you need big towing HP you might see about a kit that somebody used to produce to drop a Ford 5.0L V8 into the RRC, but that's still going to be some work. Can you get your hands on a Rover 3.9 or 4.2L V8 over there?
    July 12th, 2014
    Milton Keynes UK
    103
    Now funny that you should say Mercedes... I was looking at an OM606 with a rejetted manual pump that would produce around 275 hp and 400 lbs, found a company in Sweden who make a conversion kit to drop it in the Range Rover.. Then I discovered that you can get the same output from an OM605... With less size it should fit better!!
    Rover 3.9's and 4.2's are easy to get, but I need high torque at low revs so I really need to stick with diesel. Oh and from what I have seen the 4.6 is a better engine, and can be put back on a carb (Holley 4 brl) and still make good power without the need for ECU's!
    And big engines in a RRC... Overfinch used to put the 350ci Chevy in a Classic, and there is also kits to fit the GM V8 diesels too... only problem is they are hard to find in the UK and the Fuel pump arrangement puts me off, from what I have gathered they can be a real pain when they go wrong and very expensive to put right over here!!
  1. P38 diesel. Fuel pump swap. Does not start afterwards
    By kretslopp in forum Range Rover Mark II / P38
    Last Post: March 5th, 2017, 03:58 AM
  2. The P38 6.2l budget diesel swap thread...
    By kingsly in forum Range Rover Mark II / P38
    Last Post: May 24th, 2015, 06:13 PM
  3. New shortblock or diesel swap?
    By REDrum in forum Range Rover Classic
    Last Post: August 23rd, 2013, 06:56 PM
  4. Mercedes Diesel Swap
    By in forum Range Rover Classic
    Last Post: August 30th, 2012, 11:35 AM
  5. Engine swap? Gas to diesel?
    By justinjoven in forum Range Rover Mark III / L322
    Last Post: March 14th, 2011, 06:14 PM
