RRC 3.9 not pumping any oil
Results 1 to 15 of 24
Thread: RRC 3.9 not pumping any oil
    January 24th, 2017
    Carpentersville IL
    I have a question on my RRC. Its a 92 v8 3.9 and unfortunately it has had to sit for about a year in a garage due to me starting to work on it and then other life events happening preventing me from putting it back together. Anyways I'm trying to get it back up and going so I can finish it up but for some reason I'm not getting any oil to the top end of the engine and I'm not sure why.
    I have tried packing the pump with Vaseline,
    I have taken the top oil cooler line off and put a vacuum to it,
    I have taken the distributor off and made a tool to spin the pump with a drill,
    I have poured oil down the cooler pipes,
    I have replaced the pump and gears with ones from a parts car,
    and I have taken the oil pan off and cleaned the pick up tube and put a new gasket on both the tube and pump.
    Everything I try doesn't work and I still cant get it to pump oil, even with the cooler line undone i dont get any oil out of it.
    Any help or suggestions would be awesome,
    Thank You!
    FRESHMAN ROVER HDvideo4K's Avatar
    December 3rd, 2016
    Blue Mountains, Australia
    147
    Re: RRC 3.9 not pumping any oil
    The pump gear to timing chain housing tolerance is fairly critical. Were the oil pump gears or timing case changed? I had the same issue until I found the right gear/housing combo. A new housing requires a new gear set. A second hand housing is a nightmare. After three years since the re-build and in freezing conditions, it might take 30 seconds before the light goes out but it's instant when the motor is hot. (I put that down to tolerances changing due to temperature/expansion/contraction...)
    PS: I've tried every oil and filter combination under the sun but good ole 100% mineral Shell 15W-40 plus a genuine Land Rover filter (with non return valve) still works best.
    Craig Marshall: Film Maker and Tour Operator
    2005 Range Rover L322 HSE 4.4 Litre 5 Speed Auto
    1993 Range Rover 'Classic' Vogue SE 4.6 Litre 4 1/2 Speed Auto (sold)
    2006 RR 'Sport' TDV6 (commercial 4x4 tour vehicle until sold)
    2002 RR L322 HSE TD6 (commercial 4x4 tour vehicle until traded on above)
    2000 Defender Td5 110 Station wagon (commercial 4x4 tour vehicle until traded on above)
    1998 Defender Tdi 130 Dual Cab (traded on above)
    1964 Series IIa SWB (still a mate's daily drive)
    Premium Member crazyguy's Avatar
    October 28th, 2013
    Palm Beach, FL
    310
    Did you change the timing cover gasket? That was the problem with mine. there are two very similar ones, only the correct one has one small extra hole for oil. My guess is you've got the wrong one.
    1990 RRC. 4.2 wearing green.
    April 15th, 2014
    Wimbledon UK
    51
    You could also check the oil pressure relief valve to make sure it's not stuck open.
    June 11th, 2016
    northern va 22003
    343
    it is in the repair manual, pack the pump gears with vaseline or grease.
    January 24th, 2017
    Carpentersville IL
    There were some wear marks on it but nothing that I would say is excessive. I took the gears and the oil pump assembly off of a parts car that I have but I did not transfer the timing cover with it.
    January 24th, 2017
    Carpentersville IL
    And no I have not taking the timing cover off but I'm not sure if the guy before me did or not but I'm pretty sure I had oil pressure when I first bought it
    October 28th, 2013
    Palm Beach, FL
    310
    he said he did that in the first post.
    December 3rd, 2016
    147
    I suspect you'll need to take the timing cover off the parts car to mate with it's original gear set. I'd bought new gears for the second hand timing case but we could not get pressure after trying ever trick in the book. In desperation, we put my old gears in and it eventually got pressure. As previously mentioned, the non-return valve could also be stuck.
    April 8th, 2015
    Fort Myers, FL
    60
    Quote Originally Posted by crazyguy View Post
    I wonder if that's the problem with mine... I still haven't investigated it but that seems like the most likely explanation.
    Paul
    1993 Range Rover LWB
    June 11th, 2016
    northern va 22003
    343
    correct, sorry typed before my brain could process...lol.
    January 24th, 2017
    Carpentersville IL
    I think i will try taking the timing cover off the parts truck and see if that will work. Is the timing cover for the 4.2 motor the same for the 3.9? My parts truck has a 4.2 in it (which i plan to swap at some point). Whats this thing about the gasket for the timing cover being a bit different? Im going to order a new one so i want to make sure i get the right one.
    June 11th, 2016
    northern va 22003
    343
    as long as they are equal belt drives, that is either both motors serpentine or both motors multi vee belt.
    if not equal, the cover will work for testing purposes but you won't be able to drive the ancillaries unless you do the component swap over, on a serpentine belt the water pump rotates opposite and it is a totally different animal than vee driven.
    one detail many of us missed, the distributor drives the oil pump shaft. Does the dizzy have the little wobbly piece at bottom of gear? if not them you may not be driving the pump.
    other than that, you may need to retrace your work for something missed.
    January 24th, 2017
    Carpentersville IL
    I am 99% sure that they are both V belts but I will double check. And I did pull the distributor to check to make sure that everything was there.
    June 11th, 2016
    northern va 22003
    343
    oh darn the mystery only deepens, could very well be the engine bearings are so worn they just don't build pressure. normally the packing of the gears with grease does the full trick, maybe so much sludge in the motor has cloged the oil gallery.
    get a hold of Dan at D & D fabrications aka aluminumv8.com he does lots of rover engines.
    something is definitively amiss but what is it? the million dollar question.
    good luck.
  1. Anyone else have problems pumping gas?
    By engineerrs in forum Range Rover Sport II / L494
    Last Post: October 19th, 2016, 01:37 PM
  2. 92 RRC 3.9L Oil Light and oil pressure (psi) question
    By DesertGuy in forum Range Rover Classic
    Last Post: July 17th, 2016, 03:46 PM
  3. Pumping noise when braking
    By hp.robinson in forum Range Rover Mark II / P38
    Last Post: July 22nd, 2013, 08:43 PM
  4. EAS Pump Buzzing not Pumping
    By efarmer in forum Range Rover Mark II / P38
    Last Post: June 23rd, 2013, 05:39 AM
  5. manually pumping up eas?
    By jaysky25 in forum Range Rover Mark II / P38
    Last Post: December 18th, 2012, 04:17 AM
