RRC 3.9 not pumping any oil - Page 2
Results 16 to 23 of 23
Thread: RRC 3.9 not pumping any oil
    CSK
    CSK is offline
    January 21st, 2010
    Dark Side Of The Moon, New Zealand
    125
    Re: RRC 3.9 not pumping any oil
    Quote Originally Posted by HDvideo4K View Post
    PS: I've tried every oil and filter combination under the sun but good ole 100% mineral Shell 15W-40 plus a genuine Land Rover filter (with non return valve) still works best.
    The Mahle OC 261 filter is also great. My oil pressure light goes out immediately on cold start. Have tried Wix and Britpart filters but they too about 10 seconds for oil light to go out, less when warm.
    In V8 land we're better and we know it.
    FRESHMAN ROVER HDvideo4K's Avatar
    December 4th, 2016
    Blue Mountains, Australia
    139
    Quote Originally Posted by CSK View Post
    Thanks. I've sold the Classic now so I'll see if they are available 'over the ditch' and let the new owner know.
    Craig Marshall: Film Maker and Tour Operator
    2005 Range Rover L322 HSE 4.4 Litre 5 Speed Auto
    1993 Range Rover 'Classic' Vogue SE 4.6 Litre 4 1/2 Speed Auto (sold)
    2006 RR 'Sport' TDV6 (commercial 4x4 tour vehicle until sold)
    2002 RR L322 HSE TD6 (commercial 4x4 tour vehicle until traded on above)
    2000 Defender Td5 110 Station wagon (commercial 4x4 tour vehicle until traded on above)
    1998 Defender Tdi 130 Dual Cab (traded on above)
    1964 Series IIa SWB (still a mate's daily drive)
    April 8th, 2015
    Fort Myers, FL
    59
    I worked on mine today... rebuilt the oil pump and filed it with vaseline. That did not work even though I almost burnt the drill waiting for it to prime (clockwise). I'll take the timing cover off tomorrow and check the timing cover gasket and apply suction to the oil cavity to see if I can get oil out of the pan.
    Let me know if you get yours to work!
    Paul
    1993 Range Rover LWB
    FRESHMAN ROVER argyle219's Avatar
    December 6th, 2014
    Orlando, FL
    36
    I had a similar problem when I rebuilt the top end of my motor. I actually ended up breaking a rocker arm trying to figure it out. I was fortunate to have PT Scram in town one day and convinced him to take a look. He showed me a plug on the oil pump just above the oil pressure sensor, I have a 1988 model with out the oil cooler so this may not apply to later models. He removed that plug and knew right away there was no oil getting to the top end. If you take that plug out and no oil is common out then your pump is not primed. I borrowed a vacuum pump from work, a HDPE sample port with similar threads, teflon tape(I think the threads are some weird British pipe thread), and the knock out from my break bleeder kit, hooked everything up,applied vacuum and voila I had oil in the KO container. Put the plug back in fired her up and a second later the valve train went silent and was purring like a kitten. Hope that helps.
    Sent from AutoGuide.com Free App
    April 8th, 2015
    Fort Myers, FL
    59
    Quote Originally Posted by argyle219 View Post
    ...there was no oil getting to the top end.
    I believe this is my problem as I'm drawing old from the sump (there was more oil in the filter than when I filed it and if the oil when coming from the cooler, it wouldn't be fresh oil).
    It is my understanding that when turning the oil pump clockwise with the drill, I should be able to see oil flowing with valve covers off. I can't figure out what I could have done to block an oil passage when I did the head gasket job. I'm really confused.
    Paul
  8. #21
    April 8th, 2015
    Fort Myers, FL
    59
    Any idea what could prevent the oil from flowing to the top of the engine when the pump is primed?
    Paul
  9. #22
    June 11th, 2016
    northern va 22003
    314
    Quote Originally Posted by Paul Thomas View Post
    blocked passages, by either sludge or improper head gasket, low oil pressure or low oil volume delivery, bad pump, internal failure of pump components i/e missing or stuck relief valve, low oil level in sump.
  10. #23
    Premium Member crazyguy's Avatar
    October 28th, 2013
    Palm Beach, FL
    309
    incorrect front cover gasket (happened to me)
    1990 RRC. 4.2 wearing green.
  1. Anyone else have problems pumping gas?
    By engineerrs in forum Range Rover Sport II / L494
    Last Post: October 19th, 2016, 02:37 PM
  2. 92 RRC 3.9L Oil Light and oil pressure (psi) question
    By DesertGuy in forum Range Rover Classic
    Last Post: July 17th, 2016, 04:46 PM
  3. Pumping noise when braking
    By hp.robinson in forum Range Rover Mark II / P38
    Last Post: July 22nd, 2013, 09:43 PM
  4. EAS Pump Buzzing not Pumping
    By efarmer in forum Range Rover Mark II / P38
    Last Post: June 23rd, 2013, 06:39 AM
  5. manually pumping up eas?
    By jaysky25 in forum Range Rover Mark II / P38
    Last Post: December 18th, 2012, 05:17 AM
