Brake pump not working
Results 1 to 6 of 6
Thread: Brake pump not working
    Premium Member crazyguy's Avatar
    October 28th, 2013
    Palm Beach, FL
    313
    Hello all,
    My brake pump has stopped working. I've checked the relays and they're working, and I appear to have 12v at the pump. When I turn the key I get nothing. Unfortunately the lady was driving the truck when it appears to have failed so I don't know what exactly happened. She didn't notice. Any help would be greatly appreciated. Brakes and pump worked great before with only a very sporadic odd sound out of the pump (less than once a month and only 3 times ever). I'd much prefer to not have to purchase a new pump. Is it serviceable?
    thanks!
    1990 RRC. 4.2 wearing green.
    July 13th, 2008
    New York, USA
    233
    Re: Brake pump not working
    Technically, the pump is rebuildable (http://www.rangerovers.net/repairdet....html#pumpdiag)
    IMO, it's simpler to find a used one elsewhere and installing it real quick. All year classics have the same pump but the connector might differ from years. Super simple to splice the correct connector in and be on your way again.
    1990 Range Rover - http://www.defendersource.com/forum/...irs-60356.html
    1995 Range Rover LWB - daily driver
    October 28th, 2013
    Palm Beach, FL
    313
    good advice. now to find a replacement!
    October 8th, 2015
    West Virginia
    18
    I just had this happen. I tested everything like you did and decided to replace the relay anyhow before shelling out the cash. It worked and couldn't believe it. It might be worth a shot.
    1995 RRC LWB
    23,542
    Since he had 12v at the pump connector then his relay was working properly.
    October 28th, 2013
    Palm Beach, FL
    313
    yep, relays are working. bummer too, since that's the easy fix.
  1. Abs pump working in delay
    By noamh23 in forum Range Rover Mark II / P38
    Last Post: September 14th, 2016, 11:36 AM
  2. Quick fix to air up the tank without a working pump?
    By kingsly in forum Range Rover Mark II / P38
    Last Post: June 21st, 2016, 01:34 AM
  3. Can the brake switch be bad even if the brake lights are working?
    By Angelo1 in forum Range Rover Sport / L320
    Last Post: July 3rd, 2014, 10:25 PM
  4. 1989 rrc Fuel pump not working while cranking NO START
    By 1962siia88 in forum Range Rover Classic
    Last Post: January 10th, 2013, 08:35 PM
