My first Range Rover Classic Project - '95 County LWB - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 58
Thread: My first Range Rover Classic Project - '95 County LWB
  1. #31
    FRESHMAN ROVER grnole's Avatar
    April 6th, 2011
    Stamford CT
    237
    Re: My first Range Rover Classic Project - '95 County LWB
    yes sorry to the OP Jeff, apologies for participating in the hijack - just comparing rust to rust...
    i actually used 1/8 flat bar to patch the lower holes you see here. Didnt want to remove the whole Cmember.
    My first Range Rover Classic Project - '95 County LWB-img_7357-1-.jpgMy first Range Rover Classic Project - '95 County LWB-img_7324.jpgMy first Range Rover Classic Project - '95 County LWB-img_7208.jpg
    1995 4.2L RRC LWB Beluga Black Tan Leather 5" Rovertym lift
  3. #32
    December 5th, 2016
    Atlanta
    39
    No worries at all guy's, I'm learning a ton here and appreciate the stories and guidance. We still have lots of areas to check for rust and now coat/protect as you've suggested. I only have weekends and my mechanic is busy right now so it's slow going.
    Some more questions.... thinking about how to make this reliable w/r/t all modern conveniences... what are your thoughts on:
    - replacing central locking with all new actuators/rebuilt/aftermarket and then andding keyless entry remote start?
    - doing heater core and blower motors while I have it all apart (could also clean all airways, vents and dash switches, lights at the same time)
    - recommendations on folks who restore replace wood veneer?
    - the list is never ending, but anything I'm missing you'd suggest?
    Thanks!
  4. #33
    December 5th, 2016
    Atlanta
    39
    Wow, great job grnole seeing the before and after!
  6. #34
    April 6th, 2011
    Stamford CT
    237
    Thanks ! Its a slow going process for me. I only have weekends, and I am teaching myself as I go.
    There are a ton of threads on central locking. In the 95 it looks to be an easy swap. The previous owner of my truck put in an auto-start and fob with an aftermarket set up. It works for the most part.... Looks to be an easy set up. There are some threads on people doing this.
    If you have the dash out, I would replace the HC and blower motor.
    Wood restoring... hmmm i dont know anyone off hand who does it for money... I have seen them do this sort of thing on Wheeler Dealers, but the episodes are always in the UK! HA. I had a friend do it himself to his own truck. I could ask him for pointers if you like?
    There is the sound system - depending how much of an audiofile you are... you could update your speakers and HU, the 95 is quite the animal for a stereo update. Mine has a nice Flipout DVD... Though the PO who did the wiring made quite a mess, if I did it over, i would do a better job...
    Seats - Do your power seats work? I bet not if the battery for the seat memory is original. The Seat ECU can be repaired... I would also guarantee your heated seats no longer work. Which could put you into the other open thread we have of installing new seat covers / while replacing / enhancing the seat elements
    I am also adding in some aftermarket gauges so I can have more accurate water temp readings, oil pressure, and battery voltage.
  7. #35
    Premium Member pl626's Avatar
    July 17th, 2014
    McLean, VA
    1,226
    As long as you've got the interior apart, it is a good idea to check/renew the heater. Be careful w/ the plastic center bezel. It's very brittle, but it can be repaired. I have a friend who repaired one which he was able to sell for $850 on flea bay.
    For wood refinishing, there's a place in CA called Madera Concepts.
    http://www.maderaconcepts.com
    Check my post on this 95 RRC rebuild thread
    http://www.defendersource.com/forum/...tml#post775276
    Results below, about $800 later.
    https://lh3.googleusercontent.com/3r...=w1024-h576-no
    Cheers,
    pc
    '95 RRC SWB Alpine White
    '95 RRC LWB Avalon Blue - Sold
    '06 E350 Sport
    '87 HD FLST with '02 Fatboy sheetmetal
    '02 Hobie Getaway
  8. #36
    December 5th, 2016
    Atlanta
    39
    Finally got to spend the good part of the day on the project... here is eye candy with the rebuilt transmission and new cross member from YRM. Thanks for the tips on the rust, I'm nearly through checking all areas except under the bonnet area of the hood.
    My first Range Rover Classic Project - '95 County LWB-img_0107.jpgMy first Range Rover Classic Project - '95 County LWB-img_0108.jpgMy first Range Rover Classic Project - '95 County LWB-img_0111.jpgMy first Range Rover Classic Project - '95 County LWB-img_0112.jpgMy first Range Rover Classic Project - '95 County LWB-img_0119.jpgMy first Range Rover Classic Project - '95 County LWB-img_0120.jpgMy first Range Rover Classic Project - '95 County LWB-img_0117.jpg
    Getting the old cross member out carefully has not been an easy task. We've removed rear quarter panels, bumper, drilled spot welds and rivets and used a sawzall to get remaining welds that are not accessible.
    Door sills look good!
    Bonnet is off to start on engine after rust remediation is complete.
  9. #37
    July 17th, 2014
    McLean, VA
    1,226
    Awesome work, Jeff!
    Sent from my iPad using Tapatalk
    Cheers,
    pc
    '06 E350 Sport
    '02 Hobie Getaway
  10. #38
    Premium Member crazyguy's Avatar
    October 28th, 2013
    Palm Beach, FL
    313
    man, you are doing a killer job.
    1990 RRC. 4.2 wearing green.
  11. #39
    February 6th, 2007
    83
    Well I'm impressed, but that might not mean much
    1992 Range Rover County SWB (Help)
    2012 Range Rover Sport SC
    2004 Discovery II (Son's)
    2007 Range Rover Sport SC (gone but not forgotten)
    2005 LR3 SE (gone but not forgotten)
    2001 Range Rover HSE (gone but not forgotten)
    2011 Honda Odyssey Tourning Elite... I know, I know...
    1965 Ford Mustang 289 K-Car
  12. #40
    July 17th, 2014
    McLean, VA
    1,226
    Jeff-did you spray the sill cavity w/ waxoyl or fluidfilm? If not, I'd take advantage of the sill finisher mount holes to blast the insides of the sills. Like the rear cm, they tend to rot from the inside out.
    Cheers,
    pc
    '06 E350 Sport
    '02 Hobie Getaway
  13. #41
    December 5th, 2016
    Atlanta
    39
    And the new cross member is in! I've seen some posts saying this was a six hour job, but it took my guys a day and a half while I worked on some easier tasks.
    My first Range Rover Classic Project - '95 County LWB-img_1873.jpgMy first Range Rover Classic Project - '95 County LWB-img_1874.jpgMy first Range Rover Classic Project - '95 County LWB-img_1884.jpgMy first Range Rover Classic Project - '95 County LWB-img_1885.jpgMy first Range Rover Classic Project - '95 County LWB-img_1886.jpgMy first Range Rover Classic Project - '95 County LWB-img_1889.jpg
  14. #42
    December 5th, 2016
    Atlanta
    39
    And the dreaded, leaking seat ECU battery... I've removed it and one of the chips with a heat gun, cleaned the board with rosin and alcohol and am now testing the traces. Some work and some do not... Not sure if it can be salvaged, not just from the circuit trace perspective, but also the chip I removed is pretty corroded.
    My first Range Rover Classic Project - '95 County LWB-img_0149.jpgMy first Range Rover Classic Project - '95 County LWB-img_0148.jpgMy first Range Rover Classic Project - '95 County LWB-img_0147.jpg
  15. #43
    July 17th, 2014
    McLean, VA
    1,226
    My friend Bill rebuilds the seat ECUs for fun. If you want a fully functioning one, he can rebuild yours or sell you one. He's "o2batsea" on this board as well as Defendersource.
    The Toshiba IC can be purchased from numerous places, I bought a few from Digikey.
    Your ECU actually looks pretty good.
    Cheers,
    pc
    '06 E350 Sport
    '02 Hobie Getaway
  16. #44
    December 5th, 2016
    Atlanta
    39
    Thanks, I reached out to Bill but couldn't resist trying myself as I was a Radio Shack bread board kit junkie as a kid.
  17. #45
    April 6th, 2011
    Stamford CT
    237
    Quote Originally Posted by jeffwm View Post
    did the same thing.... ended up sending it to bill he said i didnt do the best job...
  1. 1993 Range Rover County LWB Bringing Sexy Back
    By getlost4x4 in forum Range Rover Classic
    Last Post: September 24th, 2015, 10:19 AM
  2. 95 Classic LWB County No Start.
    By mpanic33 in forum Range Rover Classic
    Last Post: January 11th, 2012, 01:15 PM
  3. iPod Nano / 1995 Range Rover County LWB
    By thewhiterhino in forum Range Rover Classic
    Last Post: August 3rd, 2010, 11:04 AM
