Range Rover On Board Diagnostic Display
Results 1 to 5 of 5
Thread: Range Rover On Board Diagnostic Display
    October 1st, 2006
    Mobile, AL USA
    1,162
    Later model RRC came with a on board diagnostic reader for the check engine light. A rather simple but clever design allows us to figure out why the light is on but also displays multiple
    codes to make life a little easier. Under the right seat are to computer and a black box about 2"X3" the has a sticker that reads Range Rover On Board Diagnostic Display, it will display one code at a time in big easy to read red analog letters. Below are the pictures of the plugs and display, as well as instructions for resetting and reading multible codes. This should be made a sticky for future owners.
    Description of fault codes
    The fault codes are listed in order of priority. Where more than one fault exists, clearing the first fault code will permit the next code to be displayed.
    Note: Fault code 02 will show if the ECU has been reconnected. Switch on ignition to clear the display
    Clearing fault code display
    It is necessary to clear the code displayed when the fault has been rectified, and to access any fauther fault codes that may exist. Clear the fault code display using the following procedure:
    1. Switch on the ignition.
    2. Disconnect serial link mating plug, wait 5 seconds, reconnect.
    3. Switch off ignition. Wait for the main relay to drop out.
    4. Switch on ignition, the display should now reset, If no other faults exist the display will be blank.
    5. If mulitiple faults exist repeat steps 1-4 til each fault is cleared.
    Codes and their translations:
    Code 29: ECU memory check - If this fault is present all other faults are unrelible and must be ignored.
    Proceed as followed:
    1. leave battery connected
    2. Switch off ignition
    3. Wait 5 seconds
    4. Disconnect ECU plug
    5. Reconect ECU plug
    6. Switch on ignition and check diplay unit.
    Note: If fault code 29 is present again restart test sequence.
    Code 44 - Left oxygen sensor
    Code 45 - Right oxygen sensor
    Code 25 - Ignition Misfire - This code indicates that a misfire has been detected, code 40 or 50 will indicate which bank the misfire has occured.
    Code 40 - Misfire bank A - left bank
    Code 50 - Misfire bank B - right bank
    If both fault codes are present check the following components
    Distribitor cap
    Rotor arm
    Coil
    Electrical connectors
    Pick- up (air gap)
    Amplifier
    Injectors if codes 34 or 36 are displayed.
    If either code 40 or 50 is displayed check components applicable to the particilar bank that has had the misfire.
    Spark plugs HT leads
    Distributor cap
    Code 12 - Mass airflow sensor
    Code 21 - Fuel tune selector - Identifies that the tune selector circuit is open.
    Code 34 - Injector Bank A - The display will indicate if the injectors are causing the engine to run rich or lean.
    Code 36 - Injector Bank B - The display will indicate if the injectors are causing the engine to run rich or lean.
    Code 14 - Coolant Thermistor
    Code 17 - Throttle Potentiometer
    Code 18 - Throttle potentiometer input high/airflow meter low
    Code 19 - Throttle potentiometer input low/airflow meter high
    Code 88 - Purge valve leak
    Code 28 - Air leak - Check for air leaks in the following areas.
    Hose, air flow meter to plenum
    Breather system hoses to plenum
    Brake servo hose
    Distribitor vacuum advance
    Hose, purge valve to plenum
    Injector seals
    Code 23 - Fuel Supply - Check fuel supplie pressure
    Code 48 - Stepper motor
    Code 68 - Road speed sensor
    Code 69 - gearswitch
    Group 58 - Group faults 23/28 - This indicates that a fault has been resistered that is caused by the fuel supply or an air leak but the exact fault cannot be identified. Check all items outlined under code 23 and 28.
    Code 15 - Fuel Thermistor
    The second plug, one one the floor, is the serial link matin plug as well and the ECU plug.
    This is the On Board Diagnostic Display, the black box with a sticker on it.
    He won the 1995 World Series of Poker with a deck of UNO cards.
    05' Discovery 3: Johnson Rods and 33in AT's
    00' P38 4.0: Sold
    99' P38 4.0: Gone
    93' RRC LWB: Sold
    23,528
    Re: Range Rover On Board Diagnostic Display
    Once again you are a wealth of knowledge and a wiz at write ups. I've put a copy of this topside. I'm sure it will help many others out!
    October 1st, 2006
    Mobile, AL USA
    1,162
    Thanks man. I try my best to make myself useful.
    00' P38 4.0: Sold
    99' P38 4.0: Gone
    93' RRC LWB: Sold
    July 16th, 2006
    Adelaide, Australia
    1,396
    Great write up. If only we had them over here... Nice work anyway Doc.
    rufant
    1994 Range Rover LSE
    1987 BMW M3
    1987 BMW 635CSi
    1965 Ford Anglia
    2004 Whyte PRST-4
    2009 Jamis Dragon 29er
    June 30th, 2008
    Cobblers Knob, IN
    794
    Ta, Doc Leo!
    1990 RRC
    http://2guyz.info/2g/UJ/handrover.jpg
    When the people fear the government, that is tyranny. When the government fears the people, that is liberty. -- Thomas Jefferson
  1. Onboard Diagnostic Display
    By jboothmtnbkr in forum Range Rover Classic
    Last Post: July 10th, 2013, 12:09 AM
  2. OBD "On Board Diagnostic Display" RRC "Soft Dash"
    By bigbietv8 in forum Range Rover Classic
    Last Post: December 20th, 2010, 11:55 AM
  3. Range Rover Diagnostic
    By Ace 95 in forum Range Rover Mark III / L322
    Last Post: June 22nd, 2009, 08:51 AM
  4. **INFO** Classic On Board Diagnostic Display
    By Doctor Leo in forum Range Rover Classic
    Last Post: March 19th, 2009, 12:33 PM
  5. Are there any Range Rover Technicians on this board?
    By bearit641 in forum Range Rover Mark III / L322
    Last Post: April 25th, 2005, 07:09 PM
