driving with TPS disconnected
Results 1 to 5 of 5
Thread: driving with TPS disconnected
    October 15th, 2006
    Victoria BC Canada
    85
    is there any issues with driving with the TPS disconnected.
    I think i have finally found my hesitation issue. i disconnected the TPS and took her for a drive and she drives great. i plug it back in and i have hesitation issues at around 2100rpm. unplug and it runs great. and i am not showing any code. see recent: EAS stuck in High topic
    February 26th, 2008
    Bedford UK
    100
    Re: driving with TPS disconnected
    Quote Originally Posted by rezdiver
    Hello Rez,
    No critical issues as such! Over the whole range the system may try to run somewhat weaker and indeed, you may even find your fuel consumption improves but performance will be adversely affected. Lets go back to back to basics for a moment.
    One purpose of the Throttle Position Sensor is to inform the ECU of throttle position so the ECU can take that into account as it computes pulse width requirements to suit the various driving conditions encountered.
    It also informs the ECU of the rate at which the throttle is opening so in the case of fast throttle rotation requesting rapid acceleration the signal triggers the acceleration enrichment circuits.
    At full load - wide open throttle - the TPS signal triggers the full load enrichment circuits to maximise the power output.
    So, if the TPS is not connected none of those mentioned functions can take place and the ECU will only vary its fuel metering based on the other inputs from MAF meter, and temps sensors.
    The performance will be flat with no possibility of enrichment so the acceleration and full load performance will be below par. Axiomatically, if you car has problems with the TPS connected then you may pretty much assume that the TPS (its connectors or its connecting cables) is faulty.
    To confirm the diagnosis the TPS should be tested for wear. Although not written for your car, you will find a suitable procedure along with loads of other stuff about the component, here:
    http://www.vintagemodelairplane.com/pag ... Pot01.html
    and some further analysis on this forum here:
    viewtopic.php?f=4&t=22421
    Hope this helps?
    October 15th, 2006
    Victoria BC Canada
    85
    thank you for your response and the info. I will have to drive the truck with the TPS disconnected until the replacement arrives. so far I have not seen any ill effects in driving without it but i am sure as you have mentioned that i am not doing well for performance or fuel economy.
    its strange that after two days of bad throttle and finally receiving a code 17 on the read out. i disconnected the battery disconnected the TPS and reconnected the battery, i no longer have a code or check engine light.
    February 26th, 2008
    Bedford UK
    100
    Why Strange? I assume the fault code is to inform you of a TPS malfunction based on the noisy sensor (presume you read the referenced material?) so with the TPS disconnected the diagnostic software would not detect any noise - so would not show that particular fault code. - methinks??
    February 14th, 2017
    thank you so much for clear detailed explanation.
    best regards
  1. RF Disconnected. Any Consequences??
    By kennygee in forum Range Rover Mark II / P38
    Last Post: April 15th, 2011, 12:01 PM
  2. disconnected vacuum pipe
    By stub in forum Range Rover Mark III / L322
    Last Post: April 28th, 2010, 06:28 AM
  3. Remotes won't synchronise after battery disconnected
    By Mike--02 HSE in forum Range Rover Mark II / P38
    Last Post: October 11th, 2009, 06:45 PM
  4. GPS unit disconnected and/or broken?
    By hardworkingduck in forum Range Rover Mark III / L322
    Last Post: June 27th, 2009, 07:31 AM
  5. disconnected hose?
    By wpbcaptain in forum Range Rover Mark II / P38
    Last Post: July 15th, 2005, 01:18 AM
