2002 Range Rover abs/ traction control fixed.
Results 1 to 2 of 2
Thread: 2002 Range Rover abs/ traction control fixed.
    September 10th, 2013
    Post Falls, Idaho
    Hello. I am a new member, and I have been lurking. I recently purchased a 2002 Range Rover P38 with the abs and TC lights on.
    I checked all of the suspects that were posted in previous threads and wasn't getting anywhere. I did find that the front right hub had a lot of play in it, so I replaced that. While it drove better, it still didn't cure the fault.
    In one of the threads there was mention of a bad brake light switch. These switches are self adjusting and the plunger had been pushed in so far that the brake pedal arm wouldn't touch it. I removed the switch, pulled out the plunger (which took an uncomfortable amount of force ), and reinstalled .
    Now my brake lights work properly, the cruise control works, and no more abs/tc faults. To clear the lights I did have to go to a local shop to have them clear the codes, for which they charged me one half hour of labor (yahoo European Machine! ).
    Now on to the heater core o rings, climate control display, nav system,...............
    September 3rd, 2013
    North West UK
    17
    Re: 2002 Range Rover abs/ traction control fixed.
    Nice to hear you have it sorted. Expect the switch to fail again soon, happened to me just a few months ago. Think I managed another 3 weeks before it went again?
    Also check for corrosion on the white plug found in the passenger side footwell next to the white plug for the EAS having the pins covered in green corrosion can often throw up TC faults
  1. 1996 Range Rover 4.6 abs light and traction control light always illuminated
    By scottydouk in forum Range Rover Mark II / P38
    Last Post: March 11th, 2013, 03:15 PM
  2. abs and traction control lights on
    By mark.a in forum Range Rover Mark II / P38
    Last Post: June 16th, 2010, 12:06 AM
  3. ABS Traction control, any way to diagnose myself?
    By stevelkinevil in forum Range Rover Mark II / P38
    Last Post: April 14th, 2010, 02:14 PM
  4. ABS and Traction control error
    By Astar77 in forum Range Rover Mark II / P38
    Last Post: March 26th, 2009, 01:05 PM
  5. Can anyone help!! ABS + Traction Control
    By Lammie in forum Range Rover Mark II / P38
    Last Post: January 3rd, 2006, 04:27 AM
