Replacement Cylinder Heads
Results 1 to 2 of 2
Thread: Replacement Cylinder Heads
    September 12th, 2005
    Shell Cove NSW.Australia
    104
    Hello RR Fans
    i just had the great and most enjoyable job of changing my Cyl heads, but this was only after i had tryed to stop a slight oil leak on the drivers side RHD, only to find that when i removed the cyl head, there was a 5 mm gap through the head gasket,running into the valley, anyone else ever seen such a gap through there head gasket, my rangie ran fine, but a bit of smoke if pushed hard, also was starting to use oil.lol
    reguards Kevin, more to follow.lol
    Dont let my HSE go down on me...!!!
    July 26th, 2006
    Santa Monica, CA
    133
    yes, common. i have seen some with the gap by the exhaust manifold.
    EB Turbo
  1. Cylinder heads - any difference between 3.9 and 4.6?
    By argonaut in forum Range Rover Mark II / P38
    Last Post: August 24th, 2011, 01:14 AM
  2. Cylinder heads etc.
    By leftlanetruckin in forum Range Rover Mark II / P38
    Last Post: June 18th, 2011, 03:01 PM
  3. reman cylinder heads....
    Last Post: May 11th, 2011, 06:32 PM
  4. cylinder heads
    By pegasus in forum Range Rover Mark II / P38
    Last Post: August 23rd, 2008, 03:22 PM
  5. Range Rover cylinder heads
    By minisrangie in forum Range Rover Mark II / P38
    Last Post: January 27th, 2007, 12:31 AM
