ticking sound from top of engine
Results 1 to 8 of 8
Thread: ticking sound from top of engine
    February 5th, 2012
    medford new york
    30
    I have a 1999 P38 4.0 with 150 K miles.I have owned it for the last 4k miles.
    I had a loud ticking sound from the top of the engine and my low oil light came on about
    3k miles ago.My mechanic felt that the oil was not getting to the top of the engine and that was the cause of the ticking sound.
    he flushed the engine and replaced the oil.
    The sound went away for the next 3K miles.
    I had an oil change last week and after driving about 10 miles the same thing happenned.
    The oil light came on and the ticking sound came back.
    my mechanic flushes the engine again and this time replaced with synthetic oil.
    He feels that either the oil pump screen or pickup tube gets clogged.
    Why would this happen with new oil?[too thick?]
    will the synyhetic oil work or do i need anew oil pump.
    if so how big a job is a new oil pump?
    August 26th, 2007
    8,604
    Re: ticking sound from top of engine
    Synthetic oil in an ancient pushrod V8. Funny, especially considering what it was used for (Quieten it down).
    Get a new "Mechanic". One who will actually look for what the problem is, and stop guessing.
    New oil pump is the front cover, but your "mechanic" should actually get off his rear and check for oil pressure first, which is what he should have done before.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    June 13th, 2006
    Kuala Lumpur
    1,852
    Hi
    Flickering oil light means low oil pressure. The cause can be wrong oil and the oil gets too thin. Use thicker oil.
    It can also be caused by the pressure relief valve being full of sludge causing it to stay open.
    Servicing the pressure relief valves will solve the problem.
    Worn main bearings can also be the reason. This will cause more of the oil to leak from the side of the bearings then designed and result in too low oil pressure.
    There is also the possibility of dirty pick up screen and problems with the oil pump. There are some posts on here with members that had broken gears of the pump and debris inside the oil system.
    Check the oil type and the pressure relief valves first before tearing the motor apart.
    Regards
    Jos
    August 26th, 2007
    8,604
    Or, just check oil pressure...
    Before fighting with possibly stuck/seized relief valves, put a gauge on the thing.
    '03 L322 HSE
    SOPHOMORE ROVER wreckrunner's Avatar
    December 25th, 2010
    Yucca Valley, Ca
    411
    Make sure the quick lube guys are using a good quality 10w40 oil and decent oil filter, they often look up what weight of oil to use and just pour it in without realizing that the oil specified in the guide is for newish engines and not 100k plus mileage engines! Like Martin said, this is a pushrods overhead valve engine designed about fifty years ago!
    2001 HSE Epsom green
    February 5th, 2012
    medford new york
    30
    Where is the pressure relief valve and is it easily replaved?
    June 13th, 2006
    Kuala Lumpur
    1,852
    Hi
    There are two of these fitted. One is under the pressure switch the other one is fitted lower.
    With the oil filter removed you can see them.
    Check out the post:
    Low Oil Pressure, Clean pick up tube screen?
    Regards
    Jos
    April 7th, 2013
    los angeles
    34
    Quote Originally Posted by leftlanetruckin View Post
    Start here. Oil Pressure will give you lotsa info.
  1. Slight Ticking Sound and Misfire on Cyl 6 Error Code
    By mbs xk8 in forum Range Rover Mark II / P38
    Last Post: June 7th, 2013, 09:31 AM
  2. Ticking Sound, Worried About a Slipped Sleve.
    By lrscott in forum Range Rover Mark II / P38
    Last Post: September 2nd, 2009, 03:38 PM
  3. Exhaust stink, bad idle, poor MPG and ticking sound ?
    By glaesemann in forum Range Rover Mark II / P38
    Last Post: April 5th, 2009, 12:47 PM
  4. ticking sound when trying to start?????
    By HollerLWB in forum Range Rover Classic
    Last Post: December 10th, 2006, 06:31 AM
  5. Oil Light On, Rough Running, Ticking Sound
    By alex8 in forum Range Rover Classic
    Last Post: July 21st, 2006, 02:40 PM
