Funny transmission shifting
Results 1 to 15 of 19
Thread: Funny transmission shifting
    April 1st, 2013
    Virginia
    15
    My 97 Range Rover SE is acting peculiar when shifting. In normal driving (sport button not pushed) it shifts fine in 1st thru 3rd, then doesn't seem to want to go into 4th. However, when I push the sport button, it will drop into 4th gear no problem. But, it also seems that when in sport mode, I have to manually shift the gears, it won't kick down into a lower gear. This may be unrelated, but when I apply the brakes I also get the abs light, parking brake light, and traction control light on the instrument cluster for a second or so, then it goes away. Accompanying the lights is a buzzing sound. Something strange is going on, not sure where to start.
    January 12th, 2011
    Leuven, Belgium
    478
    Re: Funny transmission shifting
    What you describe in sport, almost sounds like what happens in manual (only works when in low). Could it be it thinks it's in low?
    June 4th, 2007
    Belgium
    1,069
    Looks like two different problems. The ABS-light comes on when the pressure gets to low (<140bar), which means the ABS-pump can't keep up with the demand of the brake-assist. Either your accumulator doesn't hold charge anymore (can easily be replaced) or the pump itself is worn and doesn't build up pressure fast enough.
    As for the shifting, start by checking the fluid and replace if necessary. If that doesn't change anything, look for a bad ground to the gearbox ECU.
    It certainly isn't normal that you can't get into 4th in normal but it works in sport, usually it's the other way around because in sport the ECU will try to keep the revs up. Same for downshifting, so could indeed be something in the sport/manual button.
    Filip
    April 1st, 2013
    Virginia
    15
    The truck is definitely in high range, when I put it in low you really know it. I need to change the fluid anyway, and I'll check the manual for the location of the ground to the gearbox. I'm getting no related faults relating to this either.
    January 12th, 2011
    Leuven, Belgium
    478
    Yes, but I meant that it may *think* it's in low range.
    What does the dash say when you press the button?
    April 1st, 2013
    Virginia
    15
    when I push the button, the sport button lights up and on the display it says sport, then has an s by the gear I am in. All of that seems to be working ok.
    April 1st, 2013
    Virginia
    15
    Ok, a little more detail. I just took it on the interstate, and it will shift into 4th, albeit when the rpms are above 3000, but it will shift. However, when I got home, I put it in Low Range to test it out, and I noticed no difference. The display doesn't say "low", I hear no audible tones, there doesn't seem to be any difference at all. In other words, I don't think the truck is going into Low Range. I am getting no faults related to this. Anybody have something like this happen?
    June 4th, 2007
    Belgium
    1,069
    The transfer case is controlled by a separate ECU. They are known to fail and the motor for the gearchange itself can also stick, especially when not used for a while. Plenty of threads about those problems. But I'd concentrate on the autobox first. Since you hadn't noticed you can't engage low before, I'm guessing you don't use it, so wont miss it anyway.
    One thing that could explain both problems, is a bad connection between the tranfer box ECU and the autoboc ECU. They share data about high/low (obviously), but also park/neutral (to allow shifting between high and low) and sport/manual.
    From RAVE:
    "The high/low signal to the Auto Gear Box Control Unit comes from the High range status lamp. If the Auto Gear Box Control Unit does not recieve the range information, then an incorrect gear change mode could be selected, i.e. manual rather than sport in high range and vice versa in low range. Also, the shift strategy is different between the economy modes of high and low and so poor shift quality could result."
    So Elbekko could have had it right from the start!
    Filip
    April 1st, 2013
    Virginia
    15
    I'll check that out, another thing....when I move the stick over to low range, the indicator lights still light up on the High Range side, not on the low range side.
    Premium Member tompage81's Avatar
    August 9th, 2012
    Co.Clare Ireland / Currently Living In Florida
    628
    I can almost guarantee you that your problem is a dirty MAF sensor.
    My rig suffered from the exact same symptoms when I bought it and I tried everything to fix it including changing out the transmission fluid and filter but to no avail.
    On my rig the symptoms were I'd have to drive 78mph on the interstate before she would shift up into 4th and the revs between gears were always really high.
    Then one day I took off the Mass Airflow Sensor and upon inspection the sensor was covered in dirt so I sprayed it clean with carb cleaner,left it in the sun to dry out for 20mins and then put it back together and shes been perfect ever since.
    2002 Range Rover 4.6 HSE Niagara Grey
    On Bilstein shocks & Nitto Terra Grapplers A/T
    For EAS + BeCM contact the Doctor www.becmdoctor.com
    April 1st, 2013
    Virginia
    15
    Thanks, hope that will help. I will check that this evening. You would think that if there is an issue with the MAF, it would show a fault?
    August 9th, 2012
    628
    Not necessarilly or at least it didn't on mine.Its worth checking as its a straight forward fix before getting into some of the more serious stuff.I'd advise you also to change out your transmission fluid and filter if it hasn't already been taken care of.
    June 4th, 2007
    Belgium
    1,069
    Definitely something wrong with the H-gate then. The lights should flash in the range you selected while the change is taking place, just like the indicators on the EAS rideheight selector.
    April 1st, 2013
    Virginia
    15
    As time has gone on, and I have driven the Rover more I do think when in "normal" mode, it thinks it is in "Sport" mode. When on the interstate, it will shift into 4th gear eventually when I get up to around 55 or so. It does this consistently, and if I want to put it into 4th gear sooner, I just hit the mode button which apparently puts it into manual, and it will shift right then. Anyway, I still cannot get it into Low Range. It makes no effort at all, no lights, no sound nothing, when I put it in gear in the Low Range side, it continues to be in High Range. So...I found a 98 in a pick and save yard, and pulled a lot of parts, 2 blower motors, fuse block and others as well as a BECM ($20) But....is it as simple as just replacing the one I have, or will I run into some other issues. Assuming the one I bought has no problems, will I have any issue using my key? I already have an alarm fault right now which I don't even notice, but I assume the alarm doesn't work. Anybody have any suggestions?
    December 29th, 2005
    Swindon, Wiltshire, UK
    3,736
    Sounds like a good deal you got on the parts...
    I don't understand why you're planning on replacing the BECM though? Both the transmission, and then transfer case (that does the high-low ratio change) are controlled by their own ECU's.
    The earlier P38's had issues with the transfer case motor sticking, and burning out the ECU. Apparently the newer models have a better heatsink to stop the frying of the ECU.
    Cheers,
    Marty
    http://p38webshop.co.uk/
  1. Transmission acting funny.
    By carter840 in forum Range Rover Mark III / L322
    Last Post: September 20th, 2011, 01:20 PM
  2. Funny Transmission Noises
    By OldBrit in forum Range Rover Classic
    Last Post: July 17th, 2011, 08:06 AM
  3. Transmission Shifting Issues
    By Bobcat in forum Range Rover Mark III / L322
    Last Post: March 13th, 2011, 04:01 PM
  4. Transmission shifting??
    By abovenbeyond in forum Range Rover Classic
    Last Post: April 29th, 2009, 08:22 AM
  5. transmission Shifting funny
    By Black Rover in forum Range Rover Mark II / P38
    Last Post: April 26th, 2009, 11:05 AM
