engine wan't to start
Results 1 to 3 of 3
Thread: engine wan't to start
    February 22nd, 2012
    USA
    Hi. I have 2000 range rover it over 100000 mile, a few days ago when i was stop at red light then pull over car was going hardly and make 1 beep noise as it giving in case of error but no message on dash and it happened on next 2 stop lights till i got to home. Next morning I checked transmission fluid and added car was running good. but after i park at garage wan't to start at all. I called mechanic hi plug and check BECM it's shoeing code 3941 ( i'm not sure or 3541) and i need to change left front door latch and fuel pump. can same one help me?
    LEGACY VENDOR leftlanetruckin's Avatar
    August 26th, 2007
    4,080
    Re: engine wan't to start
    Rebuilt 4.6 motors and cylinder heads, with installation available.
    Custom fabrication from sliders to bumpers.
    For all parts, go to www.socalusedroverparts.com
    Maltby, WA USA
    10,961
    Can someone help you with what?
    Door latch and fuel pump have been well discussed and written up. Search will help you out there.
    I am not sure what transmission fluid would have to do with how the engine runs.
    Codes 3941 and 3541 mean absolutely nothing without knowing what kind of diagnostics you are attempting and what equipment you are using. They certainly are not standardized nomenclature.
  1. Engine won't start
    By tbrown944 in forum Range Rover Mark II / P38
    Last Post: May 11th, 2011, 12:19 PM
  2. engine will not start
    By 8846andy in forum Range Rover Mark II / P38
    Last Post: August 15th, 2010, 02:45 PM
  3. engine won't start... need help!
    By n21williams in forum Range Rover Mark II / P38
    Last Post: August 9th, 2009, 12:37 AM
  4. Wan't to fit a single seat in rear. Help/advice needed
    By Animal Mother in forum Range Rover Classic
    Last Post: May 22nd, 2007, 12:28 PM
