why would someone bypass
Results 1 to 14 of 14
Thread: why would someone bypass
    February 14th, 2012
    west orange nj
    13
    Post why would someone bypass
    Why would someone not sure who because I brought it from a dealership that I don't think is to reputable. But they seem to have bypassed the second ecu under the drive seat I don't know what ecu it is its under another ecu has anyone ever heard of this bypass and why it's done any help would greatly be appreciate in advance thank you
    LEGACY VENDOR leftlanetruckin's Avatar
    August 26th, 2007
    4,080
    Re: why would someone bypass
    Sounds like the EAS ECU to me. have coils for suspension by chance?
    Display readout says "EAS Manual" when you first start it?
    Someone took the ignorant way out and swapped the OEM airbags for coils IMO.
    Rebuilt 4.6 motors and cylinder heads, with installation available.
    Custom fabrication from sliders to bumpers.
    For all parts, go to www.socalusedroverparts.com
    February 14th, 2012
    west orange nj
    13
    I think ignorance had alot to do with it to because it would be bad if they did put coils my car is sitting on the bump stops so there still air springs I hope I think who ever had it tried to " hit switches" or something to that effect the cord on the makeshift switch box was pretty long
    August 19th, 2009
    Bendigo, Australia.
    382
    Crazy is the word. in 99.9% of casses the problem isn't with the ecu, so I completely mis the point of what they were trying to achieve. By passing the ecu won't solve any problems, it'll just hide a bad height sensor.
    February 14th, 2012
    west orange nj
    13
    I also found this to be very strange but I am a novice. To p38 so I thought I would ask some people that would know
    December 6th, 2009
    535
    you say there is a box and cable in the bypass?
    picture is worth a thousand words...
    2001 Range Rover 4.6 SE - SD rack, sliders, ladder, steering guard, front diff guard, rear diff guard, Warn 9000 winch, factory winch tray, aluminum radiator, 265/70 Revo2s, EAS intact, no chrome... ARB 50qt fridge
    February 14th, 2012
    west orange nj
    13
    Yeah they have a household electric box that has the toggle switches for the air suspension. The baffling part to me is the fact that the wire that they ran is not in the ecu but it's connected to the wire harness coming into the car . The eas ecu was left unplugged it makes no kind of sense to me . I will take a picture and post as soon as I get home from work.
    Maltby, WA USA
    10,961
    It makes perfect sense. When the bags wear out and start to leak people start butchering things instead of fixing things. Using the field recovery information from the home pages someone has made a jumper box to manuall air up their bags so they don't have to deal with hard faults and flat suspension. These bypass systems work great until you burn out the compressor at which point you ahve even more to repair than if you had fixed the initial issues when they first appeared. There are a few members here that have done so and documented the wiring and build.
    February 21st, 2010
    Shropshire UK
    1,155
    it may just have hard faulted, if you think it won't harm anything reconnect the EAS ecu, get/make the cable and use the RSW software to see what's up.
    ***to late ^^ RRtoadhall said it better.
    Larry S
    1995 4.6 HSE
    August 26th, 2007
    4,080
    Cant wait to see this little gem....
    February 14th, 2012
    west orange nj
    13
    Rrt I think you are right because my suspension was flat I put my hand on the compressor and nothing no vibration no sound so I believe that the compressor has burnt it self out from constantly pumping air to the bags witch I think has drained my battery causing my power problem (people should realize if you don't know what your doing a short cut is just not worth it) . I'm going to get my battery check today hopefully its just needs a charge
  13. #12
    Maltby, WA USA
    10,961
    Hold on, back up a bit. You need to learn about the system and recognize what has been done with the bypass. The pump will not run without activating it using the bypass system. If you remove the bypass system then you need to have a fault reading system to identify the issues and solve them before the pump will run with the ECU hooked up. Take some time to read the field recovery section of home pages so you understand what the bypass has taken the place of. Read the sticky above and the EAS section of home pages so you understand how it should properly work. Then you can jump in and determine if your pump is fried or not.
    If I were in your shoes I'd be really happy with the bypass at this time. You can manually fill the tank to check your pump operation. You can manually fill one bag at a time to identify bag or line issues one corner at a time.
  14. #13
    February 14th, 2012
    west orange nj
    13
    I will definitely check out the field recovery information I really need all the knowledge I can get when it comes down to my range hopefully reading and asking questions on the forums will lead me in the right path thanks again everyone
  15. #14
    December 25th, 2010
    Yucca Valley, Ca
    249
    Call Scotty, buy a 'Rover Raiser'! Once you get your EAS fixed and working as it should you will be able to look at the Rover Raiser as an emergency get you home without wife killing you device!
    2001 HSE Epsom green
  1. bypass hose?
    By bowranger in forum Range Rover Mark II / P38
    Last Post: April 5th, 2011, 09:46 AM
  2. ABS bypass, stereo
    By Leav in forum Range Rover Classic
    Last Post: September 29th, 2010, 07:34 PM
  3. EAS bypass
    By middleman496 in forum Range Rover Mark II / P38
    Last Post: March 2nd, 2010, 10:42 PM
  4. EAS Bypass
    By 97rover in forum Range Rover Mark II / P38
    Last Post: October 25th, 2006, 10:07 AM
  5. P38 Immobilizer bypass
    By chrisall in forum Range Rover Mark II / P38
    Last Post: September 7th, 2006, 01:31 AM
