Test Pressure Switch?
Results 1 to 2 of 2
Thread: Test Pressure Switch?
    FRESHMAN ROVER RoverP38's Avatar
    January 18th, 2012
    Newtown, PA
    42
    Is there any way to test the EAS Pressure Switch? If so, how?
    Thanks,
    2001 RR HSE
    February 21st, 2010
    Shropshire UK
    1,155
    Re: Test Pressure Switch?
    Monitor a certain pin at the EAS ecu connector, if it shows battery voltage then the system is up to pressure @150 psi, it will show nothing [0 volts] until it switches.
    Check the main site for the details as i forget the pin No. (might be 13 though)
    Larry S
    1995 4.6 HSE
  1. Block pressure test kits
    By leftlanetruckin in forum Range Rover Mark II / P38
    Last Post: May 19th, 2011, 05:09 AM
  2. How do you test the water temp switch?
    By jon4130 in forum Range Rover Classic
    Last Post: February 4th, 2011, 04:41 PM
  3. Trinary Switch, Dual Pressure Switch???
    By phildg2000 in forum Range Rover Mark II / P38
    Last Post: October 29th, 2008, 08:29 AM
  4. ABS, ABS pump and pressure switch test
    By Breckrover in forum Range Rover Classic
    Last Post: September 22nd, 2006, 01:31 PM
  5. How to Test Dual Pressure Switch / Condenser Fan Operation?
    By twodiffs in forum Range Rover Mark II / P38
    Last Post: November 28th, 2005, 06:25 AM
