I used the instructions and pictures provided by Ron Beckett to replace my head unit bulbs several years ago and it work masterfully (Thanks Ron)! However, recently my LCD glass plate has been only revealing intermittent parts of the temperatures numbers, etc... I have made extensive searches here for more on replacing and/or repairing the LCD without a total head unit replacement (serious $$$$$$)! Due to the cost, I was fairly certain that someone here had repaired instead of replacing their existing unit. Anyway, the pictures that Ron had included on the bulb replacement also showed the inside of the unit but there are some further, more detailed questions that I need answering if possible. Therefore, I have included one of Ron's pictures revealing the inside of the unit and the LCD glass as well as picture's of mine in which my questions lie: 1. the vertical copper lines on the head unit which connect to the one's connected to the LCD glass appear corroded, any suggestions on what to use and if cleaning them is possible and 2. when refitting the LCD glass does it fit snug into the white plastic clips on all four corners of the white box that holds the bulb or if not, how does it fit there properly for replacement? Any thoughts, knowledge, would be GREATLY appreciated! Also, while I still have the unit a part, if anyone would like me to take additional pictures, let me know and I'll be glad to post for you.
Thanks,
Dean
LinkBack URL
About LinkBacks
2002 Range Rover 4.6 HSE
