The Saga - Page 2
Results 16 to 18 of 18
Thread: The Saga
    December 3rd, 2011
    Panama, Central America
    18
    Re: The Saga
    Ops well I guess you are never to old to learn.
    LEGACY VENDOR leftlanetruckin's Avatar
    August 26th, 2007
    4,080
    Re: The Saga
    Ours, nor any of the ones I have worked on, do what you described. Thus I think you have an issue, maybe in the switches themselves. No way that pressing either the over ride or cruise button should make the EAS light all the way up, unless it was in a fault mode.
    Rebuilt 4.6 motors and cylinder heads, with installation available.
    Custom fabrication from sliders to bumpers.
    For all parts, go to www.socalusedroverparts.com
    December 7th, 2011
    Houston
    40
    Re: The Saga
    On your lugnut issue, the P38 stock nuts are too large for the newer wheels. You can either machine the rims like you suggested or buy a set of lugnuts from the proper year truck. You should also be using hubcentric rings 72.6 x 70.5mm to help center things.
  1. Another engine rebuild saga
    By argonaut in forum Range Rover Mark II / P38
    Last Post: January 17th, 2012, 01:36 PM
  2. Oil Pressure Switch replacement saga...
    By Ka177ran in forum Range Rover Mark II / P38
    Last Post: May 24th, 2011, 03:05 PM
  3. FNGF. the saga begins.
    By Jagman in forum Range Rover Mark II / P38
    Last Post: December 18th, 2010, 09:04 AM
  4. The oil leak saga continues
    By mrpcar in forum Range Rover Mark II / P38
    Last Post: July 24th, 2008, 11:35 AM
  5. My EAS saga....
    By shupack in forum Range Rover Mark II / P38
    Last Post: October 8th, 2005, 05:31 PM
