Where to grease gun?
Results 1 to 9 of 9
Thread: Where to grease gun?
    FRESHMAN ROVER nuyorican420's Avatar
    March 13th, 2008
    Los Angeles, CA U.S.A.
    88
    I Just Brought a grease gun with a flexable hose. What do I grease besides the Prop shaft/U-joints?
    2002 4.6 HSE.
    GENIII's 13X,XXX miles.
    Audi A6 heater core conversion.
    EBC GN 7000 Front/6000 REAR.
    November 23rd, 2009
    Pittsburgh, PA USA
    511
    Re: Where to grease gun?
    Anything and everything you can find with a zerk fitting. Off the top of my head I don't recall any zerks for the ball joints on the P38, so props and U's will likely be it.
    96 RR SE
    03 Jag S Type R
    07 SAAB 9-3t
    95 Jeep ZJ 3" lift
    SOPHOMORE ROVER BargePilot's Avatar
    November 22nd, 2006
    The Hague area, Holland
    314
    Just did the ball joints, used OEM stuff. No zerk fittings.
    To protect your Land-Rover against theft, always remove the ignition keywhen parking.
    As an additional precaution the distributor rotor arm may also be removed.
    - Operational Manual for the Land Rover, 1950
    November 23rd, 2009
    Pittsburgh, PA USA
    511
    Did you just inject grease behind the seals or what? Mind giving me a how-to?
    96 RR SE
    03 Jag S Type R
    07 SAAB 9-3t
    95 Jeep ZJ 3" lift
    June 13th, 2006
    Kuala Lumpur
    1,013
    Hi Chris
    I think Bargepilot means that he just replaced the ball joints with new OEM units.
    These ball joints are not expensive and when clearance develops in the joint it is time to replace them. You can lift the rubber boots off and smear grease under them but you are more likely to tear them apart as they become weak when they age. This will also not ensure that grease is making its way to the moving parts where it is needed.
    Regards
    Jos
    November 22nd, 2006
    314
    Quote Originally Posted by Chris X View Post
    Hi Chris, it's as Jos said. I bought new parts from a LR-specialist. OEM, from Lemförder I think. They came pre-greased - I checked.
    Original ball joints were fine but the seals / rubber boot on one of them was torn. And that is a MOT-failure over here...
    But I see where you're coming from. I looked up a lot of ball-joint-replacement-stories on google and I noticed quite a few cars (mostly american) with zerk fittings on the ball joints.
    November 23rd, 2009
    Pittsburgh, PA USA
    511
    OH - OK I see what you are saying now Barge....I misunderstood your statement. I thought you meant you greased the ball joints (as part of a regular maintenance), my bad. Thanks for helping clear it up Jos. I should have read it more carefully.
    Yeah my Jeep has a zerk fitting on the radio I think. They are everywhere on that thing.
    96 RR SE
    03 Jag S Type R
    07 SAAB 9-3t
    95 Jeep ZJ 3" lift
    November 22nd, 2006
    314
    No, my bad, I should have written 'replaced'.
    I thoughted I spoked Engleesh, but I mistaked me.
    You dig?
    November 23rd, 2009
    Pittsburgh, PA USA
    511
    I dig brotha, I dig...I don't think I speak the Queen's English anyway, yours is probably better than mine. LOL!
    96 RR SE
    03 Jag S Type R
    07 SAAB 9-3t
    95 Jeep ZJ 3" lift
  1. Grease fittings
    By DocJoseph in forum Range Rover Mark III / L322
    Last Post: March 23rd, 2009, 07:52 AM
  2. How to drain swivel grease
    By Diggaz in forum Range Rover Classic
    Last Post: March 4th, 2009, 12:18 PM
  3. Grease fittings
    Last Post: January 22nd, 2007, 01:28 PM
  4. Hub Grease ??
    By johnw in forum Range Rover Classic
    Last Post: July 10th, 2006, 07:59 AM
  5. Silicone Grease
    By 984.6HSE in forum Range Rover Mark II / P38
    Last Post: October 16th, 2005, 07:13 PM
