Intercooler hoses collapsing
Results 1 to 10 of 10
Thread: Intercooler hoses collapsing
    August 27th, 2009
    Kandy, Sri Lanka
    154
    Hi guys,
    My dad said today, while driving, the power suddenly cut off and he could only rev to about 2500 rpm and no more. After this i did some digging around. Some suggested it's the hosses collapsing, some said clogged intercooler, some said exhaust and some suggested serviciing the turbo. So i let my dad know on these and a little while ago i got the report.
    Both intercooler hoses are collapsing for some reason. He has run the engine without the air filter and it produces the same result. Also mentioned that hoses are soft & mellow.
    Turbo unit was serviced recently. Also my dad had done something to the hoses to reinforce them and said the hoses are still collapsing but not as much as before.
    Any suggestions?
    -- Gayan --
    P38/L322 Convert -- 1998 -- Sentorino Black Range Rover
    August 26th, 2007
    8,482
    Re: Intercooler hoses collapsing
    I know the intercooler/CAC hoses on the stuff I mess with are all reinforced with a spiral wire inside the hose itself to make it keep its shape.
    Maybe try to get some newer hoses and see if that cures it.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    FRESHMAN ROVER mcapinha's Avatar
    July 30th, 2010
    Lisbon, Portugal
    122
    +1 on what Martin said: replace the hoses. When they collapse they limit air flow to the engine, reducing power. This is often accompanied by white smoke from the exhaust.
    If you can't source OEM/original hoses for your DSE you can always replace them with an aftermarket hose of equal diameter.
    1980 Land Rover Series III 88'' || '98 Range Rover 2.5 DSE
    August 27th, 2009
    Kandy, Sri Lanka
    154
    Thanks guys,
    Just wanted to confirm this. I'll let my dad know what should be done.
    Thanks again.
    -- Gayan --
    January 31st, 2011
    162
    Are we talking about a turbocharged diesel engine?
    Almost impossible for intercooler hoses to collapse on a diesel, unless there was a blockage in the intake line.....like the intercooler itself.
    August 27th, 2009
    Kandy, Sri Lanka
    154
    @zhoey
    Yes this is a diesel.
    -- Gayan --
    January 31st, 2011
    162
    Quote Originally Posted by gunemalli
    @zhoey
    We have a Freelander TD4 as well.
    I use these in place of the original LR ones and I think the quality is so much better.
    Probably cheaper than original LR ones from a dealer.
    http://samcosport.co.uk/
    July 30th, 2010
    Lisbon, Portugal
    122
    Quote Originally Posted by zhoey
    It's hard to believe but it does happen. I've seen it on more than one DSE. If the hoses are worn, they will collapse just by squeezing them since you're limitting air flow, the "negative" pressure from the intake side will make it collapse.
    Samco has a new silicone kit for the DSE but, in my opinion, it's way overpriced at £90 plus shipping.
    Some of the local P38 owners have sucessfully replaced the hoses by stainless tubing, commonly available at any construction materials' warehouse.
    January 31st, 2011
    162
    Quote Originally Posted by mcapinha
    And does this stainless steel tubing allow for any flexibility between engine and intercooler, the latter being mounted on the chassis.
    April 10th, 2006
    Seascale UK
    446
    you could always try island4X4
    http://www.island-4x4.co.uk/-c-5_72_...page=2&sort=3a
    Tony
    99 2.5 DT 127K (UK miles) still on air
  1. Longer Brake Hoses - Donor Hoses Needed
    By p38rhino in forum Range Rover Mark II / P38
    Last Post: April 22nd, 2011, 06:39 AM
  2. Should i flush intercooler?
    By umitbat in forum Range Rover Mark III / L322
    Last Post: October 4th, 2010, 01:07 AM
  3. oil in intercooler / pipes - any ideas
    By v8bobber in forum Range Rover Mark II / P38
    Last Post: July 28th, 2007, 01:09 PM
  4. 2006 Intercooler
    By davepl in forum Range Rover Mark III / L322
    Last Post: April 28th, 2006, 06:52 AM
  5. Supercharged with or without intercooler
    By sportman in forum Range Rover Sport / L320
    Last Post: February 14th, 2006, 05:48 AM
