HEAD GASKET LEAKING EXHAUST
Results 1 to 15 of 15
Thread: HEAD GASKET LEAKING EXHAUST
    April 28th, 2010
    Lake Granbury, TX
    19
    Ok Guys, I have a 1999 P38 4.0 engine. My wife was just around the corner the other day and called me saying the Rover now sounds like a go-kart! I told her to drive it home and park it. The exhaust leak is from the passenger side head gasket. I would like to do this job myself at home just for the satisfaction of doing it myself. I have the Rave CD I downloaded from Rover.com. Please give me some tips/advise from you experts on this job. A few months ago I replaced the water pump, thermostat, radiator, and fan clutch due to top tank of radiator cracked at overflow hose fitting and leaking coolant. I also replaced 3 hoses that were soft. I've never done a HG job before. Any advise would be very appreciated. Thanks in advance!
    An ARMED society, is a POLITE society!!
    March 7th, 2010
    Michigan
    287
    Re: HEAD GASKET LEAKING EXHAUST
    Do a search, and you will get all the info you need. If you are mechanically inclined, it is an easy task, but a little time consuming.
    Tom
    2005 RR HSE Alveston Red/Charcoal('06 wheels/badges)
    1999 RR 4.6 HSE Chawton White/Lightstone
    1998 RR 4.6 HSE Oxford Blue/Lightstone (project/sold, but learned alot from her)
    If it has tits or tires, your gonna have problems with it.
    August 26th, 2007
    8,343
    Is it a GEMS or Bosch? 99 is the crossover year...
    The passenger side is the easier of the two IMO, so that is good news.
    You already replaced the water pump etc, so I think you have the basics covered
    Follow procedures and you wont have an issue.
    Remember to get the head checked for being perfectly flat and pressure tested. While it is off, you would be well advised to replace the valve seals and relap the valves. That part is free basically, you just need a valve spring compressor and valve lapping rod and paste.
    Do a search as Tom said and there will be lots of results (unfortunately), follow the tips and you will be fine. If you have any specific questions feel free to post them up.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    LEGACY VENDOR Scotty's Avatar
    March 21st, 2009
    2,054
    I have a valve spring compressor I'll sell ya 30 bucks ....
    Scotty, head womble ~ "Make Good Use of Bad Rubbish."
    http://www.becmdoctor.com
    http://www.socalusedroverparts.com
    1963 Series II A 88 Under going complete Restoration
    1996 Rangie; Milk Wagon Top Hat Motor completely rebuilt
    1999 Rangie; Callaway Epson Green completely Rebuilt
    2002 Rangie; Black on Black Restored to Original Condition
    April 28th, 2010
    Lake Granbury, TX
    19
    Thanks Guys! Bosch or Gems?? How can I tell for sure?
    August 26th, 2007
    8,343
    Quote Originally Posted by Scotty
    Thought you were taking that back?
    I saw one of these in action today and nearly fell in love....
    http://www.cylinderheadsupply.com/kl9000.html
    '03 L322 HSE
    August 26th, 2007
    8,343
    Quote Originally Posted by Cowtip
    http://www.roverparts.com/Techtips/boschvsgems.cfm
    '03 L322 HSE
    April 28th, 2010
    Lake Granbury, TX
    19
    lol BOSCH!! For sure. That's the first time Iv'e seen them like that before! Very helpful info.
    August 26th, 2007
    8,343
    Google is your friend....
    '03 L322 HSE
    April 28th, 2010
    Lake Granbury, TX
    19
    iV'E BEEN STUDYING THIS rave MANUAL. It really jumps around a lot. Anyone know where there are directions from start to finish just on the Head Gaskets? I'm not seeing a list anywhere of everything that has to come off in order to get the heads off.
    August 26th, 2007
    8,343
    WWW.Alldata.com is what I use.
    It will list the steps needed for each job, a lot more in depth than the FSM I also have.
    Mine is a Gems, otherwise I would post them up for you.
    '03 L322 HSE
    March 7th, 2010
    Michigan
    287
    Remember these words? If you need to rely on the RAVE, then it will take you a week to complete this repair.
    Take it apart, and keep everything like nuts, bolts, etc. in an order since it is your first time taking the upper end of an engine apart. Once you start disassembly, you will realise it is a simple design, the bosch injection system just makes it look intimidating.
    We will be here to help as you go
    Tom
    June 23rd, 2005
    Duxbury MA USA
    400
    Take lots of photos to help remember were things go.
    Mac
    If the Mayans taught us anything it is that if you don't finish something it is not the end of the world
    April 28th, 2010
    Lake Granbury, TX
    19
    It does look a little intimidating! But i'm gonna dive in head first! Thanks Guys! I'll post any problems I may encounter. And hopefully the END result.
    August 26th, 2007
    8,343
    Cowtip,
    Here are a few more suggestions while the head(s) are off...
    Inspect the rocker shafts for any grooves, replace if needed. They are $50 each for better than OEM ones.
    ARP head studs are way better than the OEM stretch bolts.
    A thorough cleaning before the work begins will make life more pleasant too
    '03 L322 HSE
  1. Head gasket leaking, again...
    By brian4d in forum Range Rover Mark II / P38
    Last Post: April 8th, 2010, 01:45 PM
  2. Leaking Head Gasket on 2002 4.6 HSE
    By Stevekyle in forum Range Rover Mark II / P38
    Last Post: July 8th, 2009, 04:47 AM
  3. ADVISE NEEDED?WATER LEAKING AT HEAD GASKET
    By RANGEROVERRUDY in forum Range Rover Mark II / P38
    Last Post: December 22nd, 2008, 02:57 AM
  4. 2001 - 4.6 - Head Gasket Leaking - Quick fix or replace?
    By winstonbike in forum Range Rover Mark II / P38
    Last Post: January 24th, 2008, 10:34 AM
  5. Help - leaking head gasket / porous cylinder head?
    By Salty in forum Range Rover Classic
    Last Post: August 20th, 2006, 08:13 AM
