Difficulty of Serpentine Belt Install?
Results 1 to 15 of 25
Thread: Difficulty of Serpentine Belt Install?
    March 5th, 2009
    Rockville, MD
    423
    OK, sorry for the noob question (I always have them), but how difficult is this? I saw the diagram online that shows the steps involved but telling someone the steps to something and actually doing it can sometimes be a large difference.
    Is this something I should be able to do with little mechanical know how, the diagrams, and my trusty tool box or is this something I should really have done by a professional?
    99 Range Rover
    4.6 HSE Epsom Green
    December 6th, 2009
    Sacramento, CA
    876
    Re: Difficulty of Serpentine Belt Install?
    Takes 5 minutes.
    If I remember correctly, just release the belt tensioner with 15mm socket, take off old belt, release tensioner again and put on new belt. The tensioner swivels and allows the belt to come off.
    If you have to pay a mechanic for this one, trying to fix the rest of your truck will kill your wallet.
    2001 Range Rover 4.6 SE - SD rack, sliders, ladder, steering guard, front diff guard, rear diff guard, Warn XD9000CE winch, factory winch tray, aluminum radiator, 255/85 r16 KM2s, RTE 3s, adjust Panhard rod...
    2006 LR3 SE - ARB bumper, Superwinch EP9, rack, Sasquatch rods
    2009 M1101 military trailer
    Premium Member kmagnuss's Avatar
    May 10th, 2006
    Sarasota, FL
    3,600
    DO NOT turn the wrong way on the tensioner like I did... ruining the mounting bracket.
    It shouldn't take you more than 10 minutes.
    Crooked Rod Charters www.crookedrod.com
    Tarpon... everything else is just bait
    March 7th, 2010
    Michigan
    287
    You can DIY, but having a helper the first time may save you some grief and knuckle skin
    It's just so much easier when someone else can hold the tensioner loose while you use BOTH hands to fit the belt
    JMO
    Tom
    2005 RR HSE Alveston Red/Charcoal('06 wheels/badges)
    1999 RR 4.6 HSE Chawton White/Lightstone
    1998 RR 4.6 HSE Oxford Blue/Lightstone (project/sold, but learned alot from her)
    If it has tits or tires, your gonna have problems with it.
    December 6th, 2009
    Sacramento, CA
    876
    Oh, and remember to make a mental picture in your mind of how the belt goes over/under the various pulleys. Write it down if you have to. Good luck.
    August 26th, 2007
    8,604
    If you don't have the FSM or the sticker showing belt routing, draw a picture BEFORE you start!
    After that, it will take less time than drinking a cup of coffee.
    '03 L322 HSE
    '04 DiscoII - wheeling rig
    August 2nd, 2007
    Southern California, USA
    761
    As others have already pointed out, this job is very easy-probably easier than an oil change.
    When releasing the tensioner, it's best to have a fairly long extension. I personally go for over a foot to have a really nice leverage. This makes it a piece of cake.
    Dont' forget to get the right belt-length and groove#. When putting it back, putting it back in the right orientation and having all grooves seated is the key.
    First time, maybe 1hr, but from the 2nd time around, probably only takes like 20 min.
    Oh yeah, maybe it's a good time to replace the tensioner and the 2 idler pulleys while you're at it.
    02 P38
    SoCal, USA
    May 18th, 2010
    Aberdeenshire, UK
    52
    Quote Originally Posted by spikemd
    just in case
    2001 Range Rover 4.6 Vogue (LPG)
    1971 Log Rover (Tipper, splitter, capstan, LPG)
    1968 Land Rover 109" (LPG)
    1992 Autotune Gemini kitcar (Fiat Twincam)
    http://www.log-rover.co.uk
    April 30th, 2010
    42
    Quote Originally Posted by logrover
    just in case
    The gems engine is different than that. So make sure you have a bosch if you are going to follow that. I have a gems and replacing the belt takes 5 minutes. To release tension put a socket on the tensioner and push in towards the center of the engine to release.
    1996 Range Rover 4.0 SE - North America
    March 5th, 2009
    Rockville, MD
    423
    As mines a 99, it has the Bosch setup. The reason I got nervous is because the instructions I found mentioned taking off the AC belt as well. I wasn't sure how hard it would be and the worst would be to get halfway through, then realize i was stuck... at that point, wouldn't even be able to get the car to a mechanic...
    But if it's that easy, I'm sure i'll finish (will likely take me 30 minutes) and will be like wow that was simple
    99 Range Rover
    4.6 HSE Epsom Green
    April 22nd, 2004
    Asheville, NC
    4,522
    Quote Originally Posted by 2000_328ci
    ... instructions I found mentioned taking off the AC belt as well.
    There's only one belt, it runs everything, including the A/C.
    August 26th, 2007
    8,604
    1999 was the crossover year, so could be either one. Just FYI.
    '03 L322 HSE
    December 26th, 2010
    Thornton, Colorado USA
    236
    Serpentine belts are really easy. Here's a fun trick kids! forget all those pesky belt diagrams by replacing with this simple rule! When the pulley has teeth lay the toothed side on the toothed side and if the pulley has a flat side then run the flat edge over it. You'll be surprised if you just go from pulley to pulley like this you could never use a diagram again, I haven't. Good luck.
    2000 Range Rover HSE black on black 32 inch Duratrac Arnott Custom Software Lift .50 cal Sunroof Turret Rover Raiser
    Legacy Vendor PaulP38A's Avatar
    January 23rd, 2009
    Canberra, ACT, Australia
    341
    Yup, that's the way... pretty simple when you stare it it long enough. Thanks for dumbing it down for us.
    You won't always have a RAVE manual on hand when stuck in the bush
    Cheers, Paul.
    My toys, projects and write-ups at PaulP38a.com
    February 12th, 2011
    Stockholm, Sweden
    196
    Quote Originally Posted by PaulP38A
    Cheers, Paul.
    Sorry for the threadlift, but I liked this thread and would like to share my experience.
    I replaced the pulleys and tensioner which all were worn out, the car made some very annoying sounds, especially on idle. The plastic pulleys where worn down a couple of mm and made loud grinding noises , I thought it was the alternator or maybe AC, but they seemfine and silent now.
    anyway, I decided to do this with the fan on, this was a bad decision, I would have saved prob 1-2 hours on removing the fan. Took me almost 4 hours total now including fishing for tools that i´ve dropped into the fan shroud. And to get the "clip" back on the coolant hose, when I loosend it i slid it back and it compressed over the hose, making my pliers not being able to reach the tabs, squeesing it at the same time as holding a pair of plyers and trying to get them over the tabs = frustrating.
    Anyway, easy job, anyone can do it, but REMOVE THE FAN!
  1. Serpentine belt
    By Holden guy in forum Range Rover Mark II / P38
    Last Post: August 27th, 2009, 02:05 AM
  2. serpentine belt and associated
    By Peto in forum Range Rover Mark II / P38
    Last Post: December 19th, 2008, 02:53 PM
  3. Serpentine belt
    By Vidal in forum Range Rover Mark III / L322
    Last Post: December 6th, 2008, 07:11 AM
  4. If I could just get the Serpentine belt to fit....
    By RRToadHall in forum Range Rover Mark II / P38
    Last Post: November 24th, 2007, 09:56 PM
  5. Serpentine belt
    By sweep in forum Range Rover Mark II / P38
    Last Post: August 17th, 2006, 09:29 AM
