Cleaning GEMS MAF Mass Airflow Sensor (pics)
Results 1 to 15 of 27
Thread: Cleaning GEMS MAF Mass Airflow Sensor (pics)
    Premium Member rtkraken's Avatar
    July 23rd, 2005
    Midcoast Maine USA
    1,103
    Figured it might be time to give cleaning my GEMS MAF a shot (168K miles). It was really pretty easy. I didn't elect to drill out the rivets and remove the sensor post from the housing tube because it's pretty accessible in it's assembled position.
    Here's the steps as I performed them:
    1) Remove MAF sensor housing assembly from the engine air intake (two clips MAF inlet, hose clamp MAF outlet, squeeze the electrical connector (pushing the wire in) and pull off)
    2) Gently work/pull with fingers the plastic collar inserted in front of the MAF housing intake screen and remove the screen.
    3) Take the housing outside and spray 1/2 a can (at least) into the small tube in the housing.
    (Hold the MAF housing slightly down from horizontal to allow the excess cleaner to drain. The air path through the tube exits out two ports on the underside of the "T" shaped sensor tube post. I was careful to not place the cleaner nozzle into the tube so as to avoid possible damaging of the tiny devices in the tube.)
    4) Let it dry... 1/2 hour or so...
    5) Reinstall the screen and fixing collar into the housing inlet.
    6) Reinstall the MAF sensor housing into the engine intake tubing.
    Diassembled for cleaning
    Sensor cluster before cleaning
    Ready for cleaning
    Cleaning
    After cleaning (note: you can see the color of the devices now)
    Close up of cleaned MAF sensor core devices
    Things didn't really appear too dirty. I've taken the vehicle for a preliminary drive and haven't yet reset adaptive values. The only thing I've noticed is the transmission is downshifting a little "aggressively", so something has changed...
    I'll wait for a couple days till I post a final success note...
    92 RR Classic (retired waiting resto)
    95 RR Classic (sold)
    95 RR P38 4.0 SE (180K)
    96 RR P38 4.0 SE (210K)
    07 RR HSE L322 (92K)
    01 Toyota 4Runner (170K)
    August 3rd, 2009
    Nigeria
    258
    Re: Cleaning GEMS MAF Mass Airflow Sensor (pics)
    Hi Folks, Can I use wd-40 to clean the Mass Airflow sensor
    May 10th, 2006
    Sarasota, FL
    3,573
    Quote Originally Posted by Edable
    Absolutely not.
    23,117
    OMG Oiling your MAF is a big no no. It needs to be spotlessly clean and free from any deposits. WD-40 will have left a nice layer of film on it that will ATTRACT dust and dirt and that booger will pack up faster than a mother in law coming for a visit.
    August 3rd, 2009
    Nigeria
    258
    Thanks Guys,that would have been terrible.but what about methlated spirit(Methyl ethanol)
    23,117
    I have to admit I misread your first post and thought you had already used WD-40. MAF cleaner is $4 or $5. Just go pick up a can at any parts house adn do it right.
    August 3rd, 2009
    Nigeria
    258
    Guys am in Nigeria,Gone in search of the MAF cleaner,but cant find any, hence my search for a substitute
    February 21st, 2010
    W.Midlands UK
    2,555
    carb cleaner or electrical contact cleaner, i've used carb cleaner and heard about the elec. contact being used to good effect.
    Larry S
    1995 4.6 HSE
    August 3rd, 2009
    Nigeria
    258
    ok, will get a carb cleaner, thanks
    May 10th, 2006
    Sarasota, FL
    3,573
    Sometimes carb cleaner leaves a film. Spray some metal with it first and see if it leaves any residue behind.
    Electrical contact cleaner would be better. Or maybe the carb cleaner followed by a swipe with rubbing alcohol.
    August 3rd, 2009
    Nigeria
    258
    Ok will do, thanks guys
    February 21st, 2010
    W.Midlands UK
    2,555
    good point, it should evaporate away very quickly and leave no film.
    Larry S
    1995 4.6 HSE
    23,117
    Beter yet, spray some on a window. If you can;t see through the spray area it will leave a film on the MAF.
    November 23rd, 2009
    Pittsburgh, PA USA
    542
    To carry on - some electrical contact cleaners also contain a lubricant - it should say so on the can somewhere. So pick carefully if you go that route. The idea about spraying it on a window to check for residue is excellent!
    96 RR SE (dead 7/10/12- RIP)
    03 Jag S Type R
    07 SAAB 9-3t
    95 Jeep ZJ 3" lift
    07 Jeep WK 4.7
    April 21st, 2008
    Melbourne Australia
    443
    ITS ALSO VERY IMPORTANT TO ENSURE IT HAS HAD PLENTY OF TIME TO DRY OUT PROPERLY BEFORE REFITTING AND STARTING
  1. Mass Airflow Sensor Location
    By nvr_home in forum Range Rover Sport / L320
    Last Post: April 14th, 2015, 07:55 AM
  2. Mass Airflow Sensor and mpg
    By ainiguez in forum Range Rover Mark II / P38
    Last Post: February 1st, 2015, 02:57 AM
  3. Mass airflow sensor question?3.9 liter engine.
    By bear54 in forum Range Rover Classic
    Last Post: February 25th, 2008, 03:39 AM
  4. Mass Airflow Sensor...
    By yrunvus in forum Range Rover Mark II / P38
    Last Post: March 19th, 2006, 10:17 AM
  5. Replace Mass Airflow Sensor?
    By klthomascpa in forum Range Rover Mark II / P38
    Last Post: July 20th, 2005, 12:34 PM
