Hi everyone, thanks in advance for any help or advice. After fixing the wipers on my 2001 P38 HSE 4.6l, I have run into a much bigger issue.
Ever since I bought it, after shutting engine off with key still in ignition, it would say "transfer neutral" on the message console. It would drive fine though no problem.
Well today, I go to start the RR and it started fine no problem, put it into drive and would not move in forward or reverse or any of the other gears. Then when I put it back in park, a nice grinding sound (little park locking thing I assume). Anyway, I figured it had something to do with the "transfer neutral" message from before, which is not currently on the message console.
SO, I pulled it out of where it was parked with the Jeep (in neutral!), then pushed it into the garage and tried to start it again, and no start. When turn the key, a loud clicking from starter solenoid area. Several dash lights come on, then off quickly with the clicking. Engine barely turns over (less than 8th turn of crank) Checked battery voltage, fine. Tried to jump, no effect. Checked electrical connections going to starter, all good. Did I do something wrong pulling/pushing it into the garage?? It will not start now
Kind of in pinch here because it won't start so I cannot diagnose the first issue. I love this truck and learning on it, but this is a little much!
Thanks again for any help!!
