Identify audio system
Results 1 to 6 of 6
Thread: Identify audio system
    April 20th, 2017
    Netherlands
    7
    Hi,
    I'm obviously new here, though I have been lurking here for quite a while. We recently bought a 1996 Range Rover, and have some problems with the audio, the drivers side speakers are not working unless you really crank up the volume.
    I've read a lot of topics here about the different P38 audio system. Is there any way to identify the system installed in my RR without having to pull the door card? The previous owner installed an aftermarket HU so I can't base it on the stock head unit.
    Thanks in advance!
    23,542
    Re: Identify audio system
    Does it say Harmon Cardon on the tweeter on each front door panel? If so then you have the highline audio. if not then you a lower system.
    SOPHOMORE ROVER Ferryman50's Avatar
    October 7th, 2015
    Purmerend Netherlands
    319
    As it has already an aftermarket HU it is probably not the system with the DSP amp in the boot, as it is not possible without an extensive hardwire change.
    If you pull the doorcard, in that case you will notice an individual amlifier in each door. If it is your HU at fault you can swap it with any HU that has a pre-amp output, I've had one from Sony in the past (in a different make of car). If that is going to work for front and rear or just front-stereo I don't know, marty_nz on here has done several writeups about changing the wiring. He knows all the ins and outs.
    Tony.
    2000 P38a 4.6 running on LPG
    ex Classic 3.9 Brooklands
    ex 3 other Classics to donor the Brooklands
    ex 109" Santana Cazorla (the Spanish lazy beast)
    April 20th, 2017
    Netherlands
    7
    I've read about the dsp amps. I hope thats not the system i have! I will pull the door card and check if there is an amp in the door. Tweeter did not have HK on it. Not on the inside or on the outside.
    Is it possible to not have the dsp amp, and not have separate door amps?
    SENIOR ROVER Orangebean's Avatar
    February 22nd, 2015
    South Devon, UK
    1,105
    Quote Originally Posted by avdhulst View Post
    On the factory fit systems, no. You either have one or the other. Yours wont have DSP. It's too early. I'm pretty sure it appeared in '99.
    All bets are off about whether the door amps in yours are still there/ in use though. When the new head unit was fitted it could just have been direct wired to some or all of the speakers, bypassing the door amps completely.
    It could have been installed as Ferry says above, using the pre-amp out on the head to drive the door amps. If that's the case it'll most likely be quieter than standard with a nasty buzz as the door amps need to be driven with a "balanced" signal, which the pre-outs on the head aren't.
    The best way to install an aftermarket head is to drive the door amp via attenuators from the speaker outputs of the head. A search on ambler attenuator on here will bring up details.
    You're going to have to dig in and find out exactly what you have.
    EDIT- by the way, don't get too hung up looking for HK badges on speakers. You can still have a High End system without an HK badge in sight. My '95 HSE has 3 speakers in each front door, 2 in each rear door and a powered sub in the load area- all factory.
    Currently caring for (in order of attention demanded):
    2002 4.6 Range Rover Vogue SE (A) LPG (Patience- happy and healthy)
    1995 4.6 Range Rover HSE LPG (in remission)
    1974 Triumph TR6 (waiting for new workshop to be built)
    2002 Daewoo Matiz (Really?! Family hack
    2002 Mazda Bongo Camper (another family hack)
    1987 ish RR Classic/ Defender/ S3 3.5i hybrid (sold)
    1976 Triumph Stag (restored/sold)
    April 20th, 2017
    Netherlands
    7
    I do have 3 speakers in the front doors, for as far as i can tell there's no sound coming from the right. Guess i'll have to pull the doorpanels when i have the time. I'll report back when i have more info.
  1. New Audio System a Must
    By ethosb in forum Range Rover Mark III / L322
    Last Post: March 11th, 2016, 11:58 AM
  2. RRC softdash - Sound System - Identify and upgrade
    By Sadn3ss in forum Range Rover Classic
    Last Post: November 15th, 2015, 04:47 PM
  3. Can you identify this part of the cooling system?
    By ajsno2 in forum Range Rover Mark II / P38
    Last Post: January 1st, 2013, 02:08 PM
  4. Can anyone identify this phone system?
    By mike torrisdale in forum Range Rover Mark III / L322
    Last Post: June 25th, 2012, 03:44 PM
  5. 2003 RR Custom Sound Quality Audio System by JML Audio
    By jmlaudio in forum Range Rover Mark III / L322
    Last Post: August 10th, 2007, 01:14 AM
