cruise speed input signal
Results 1 to 6 of 6
Thread: cruise speed input signal
    February 16th, 2017
    ecuador
    4
    Hi, I dont know why in my 1998 4.6 p38, at connector c255 pn 20 there is no reading voltage (no 5v stationary no 3.5 v wheels turning, with ignition key in pos II). My speedo works fine, so the output signal from the Z108 (ABS ecu) pin 28 to the becm (road speed) is working.
    some ideas?
    The output signal from the becm connector 256 pin 16 (road speed to instruments pack) is the same (exactly the same) as the output signal from the becm connector c255 pin 20 (road speed to cruise control)? (both are yellow wires!!!, both are road speed signal....)
    thanks
    November 11th, 2013
    Heathrow, United Kingdom
    317
    Re: cruise speed input signal
    It really needs an oscilloscope to check the signal properly. You might get away with an LED & Resistor to see the pulse with wheel turned by hand.
    Something like this will easily do the job with a laptop.
    February 16th, 2017
    ecuador
    4
    thanks. But... easily with a laptop???? ....how???
    My idea was to connect then connector 256 pin 16 directly (via wire) to the connector c243 pin 11 (Cruise control ecu) instead of connect the from connector c255 pin 20 to the connector c243 pin 11..... what do you think??? may be i will cause a becm shortcut or fire some where???
    sorry for my poor english...
    November 11th, 2013
    317
    Simple first check is to unplug both connectors, and check the wiring for continuity end to end. While you're doing that also check the connectors for corrosion, and clean the contacts if required.
    February 16th, 2017
    ecuador
    4
    thanks, but remember i posted "I dont know why in my 1998 4.6 p38, at connector c255 pn 20 there is no reading voltage (no 5v stationary no 3.5 v wheels turning, with ignition key in pos II). My speedo works fine, so the output signal from the Z108 (ABS ecu) pin 28 to the becm (road speed) is working.
    some ideas?" ...then my real problem es that i dont have speed signal to the cruise control...
    November 11th, 2013
    317
    Measurements of the speed signals using a multimeter are challenging at best. It depends a lot on what Averaging or RMS adjustments the multimeter actually does.
    Also, many of the outputs in the P38 electrics depend on pull-up or pull-down resistors in the destination ECU, so often you need both connected for the measurement to work.
    If your readings from BECM on "C255 Pin 20" and "C256 Pin 16" are "exactly the same" then surely both are working ? In this case the issue is either the Cruise ECU, or the wiring between this and the BECM.
    If the readings from C255 & C256 are different, then the problem maybe the BECM, but is more likely to be a short in the Cruise ECU, or a bad connection in the wiring to the cruise.
    In any case debugging pulsed waveforms really needs an Automotive Oscilloscope.
  1. Cruise control signal out of range fault
    By _ASH_ in forum Range Rover Mark II / P38
    Last Post: April 7th, 2015, 02:09 PM
  2. Cruise control - can't lower speed
    By code- in forum Range Rover Mark II / P38
    Last Post: December 22nd, 2012, 06:55 PM
  3. VSS (Vehicle Speed Signal) and Reverse for GPS
    By DucksP38 in forum Range Rover Mark II / P38
    Last Post: July 23rd, 2010, 02:59 AM
  4. Engine Speed Signal from Ignition Coil to Fuel Injection ECU
    By Tudor in forum Range Rover Classic
    Last Post: January 23rd, 2008, 03:26 PM
  5. cruise control keeps increasing speed
    By nsx4pete in forum Range Rover Mark II / P38
    Last Post: January 20th, 2007, 05:32 PM
