Strange no start problem: Ghost in the machine?
Results 1 to 8 of 8
Thread: Strange no start problem: Ghost in the machine?
    September 16th, 2016
    Irvine, CA
    25
    Hello all,
    I have a 1996 4.6 which I've owned for about 6 months now. Parts replaced as of 3 days ago: New AGM Battery, New 8mm Wires, New Spark Plugs
    The P38 started normally yesterday morning and I drove it to work. I tried to start it in the afternoon and it wouldn't turn over, the starter would not crank. I tried it a few times, and attempted to jump start it, to no avail. With Key in position 1, all lights are normal, and I can hear a relay clicking. With Key in position 2, I get nothing.
    Had it towed over on a flat bed to my Indy, and as soon as it was unloaded, it started right up as usual TWICE in a row and I moved it a couple of feet and shut it off. I tried it again 2 minutes later, and nothing! Same symptoms as before.
    When it doesn't crank, it makes no difference if the gearbox selector is in Park or Neutral, it still will not start.
    Where to start please?
    Thank you,
    Samer
    Current: 1996 P38 4.6HSE
    Sold: 1986 D110 CSW 5-Door
    January 21st, 2017
    Danmark
    Re: Strange no start problem: Ghost in the machine?
    Is the lights in the dash (alternator, oil etc.) still lit when you turn over to crank? If so, your starter (relay, but it is a part og the starter) is proberly shot.
    Best Regards
    Jakob
    Sendt fra min SM-G900F med Tapatalk
    JUNIOR ROVER Bolt's Avatar
    September 6th, 2012
    Spending the Australian winter driving around the perimeter of the country in the 85 Classic. WCPGW?
    961
    You would start by removing, cleaning and re tightening ALL of the large cables from the battery. to the starter as well as the block. Both Pos and Neg. There are any number of threads about this and an VERY good electrical sticky
    **INFO** Electrical Troubleshooting
    Print it out, follow it, and take notes.
    you will find the issue. It is a corroded earth most likely.....
    Of course it could be a duff starter, but do not buy one first. Check the connections.
    1952 Austin Champ (Hawaii)
    1953 Austin Champ (Australia)
    1985 Classic w/ Tdi300 (Australia)
    1999 4.6 HSE, White Gold "Stitch" (Wife's Daily Driver) Sold to a new enthusiast!
    2002 4.6 HSE, White "Bolt" Daily driver (Well, not right now, as I could not find a long enough snorkel)
    Irvine, CA
    25
    Quote Originally Posted by Svaneberg View Post
    Best Regards
    Jakob
    Jakob: Yes the lights in the binnacle stay on. Are you referring to the starter relay in the fuse box, or do you actually mean the starter solenoid?
    Sent from my iPad using Tapatalk
    Thank you,
    Samer
    Irvine, CA
    25
    Quote Originally Posted by Bolt View Post
    Thank you Bolt. Will do.
    Thank you,
    Samer
    January 21st, 2017
    Danmark
    The starter solenoid 😊. If you have a mate to help you, try to crank the engine while gently tap the solenoid with a hammer ☺☺
    April 24th, 2006
    Northern California
    699
    The starter/ignition/charging circuit is really no different on a RR than any other older car. If you have voltage (enough) at the battery and at the starter and no crank, check the voltage to the solenoid. Should have 12V when you twist the key. If working by yourself, make a long wire to alligator clip to the solenoid wire at the starter and run up to the cabin. Monitor voltage while turning the key. If you have 12v+ at the battery and starter, 12v at the solenoid when hit the key, you should at least get some turn over. Nothing points to a dead starter. Slow turn would indicate not enough juice in the battery. RR's do love of healthy battery.
    '99 Range Rover HSE
    '02 Audi S6
    Irvine, CA
    25
    Thanks all for the responses. It was the starter solenoid after all. We pulled the starter out and tested it, and it was the solenoid.
    Swapped the starter, and all is good. The replacement starter cranks so much better with more "authority" if you will, which leads me to believe that it was weak and eventually on its way out, much like the solenoid.
    Thank you,
    Samer
  1. Ghost in the machine! car behaving weird! help needed
    By aman in forum Range Rover Mark III / L322
    Last Post: June 16th, 2011, 03:44 AM
  2. Ghost in the machine? ? ?
    By madice in forum Range Rover Mark III / L322
    Last Post: March 14th, 2011, 06:54 AM
  3. Strange start and run problem.
    By f250 in forum Range Rover Mark II / P38
    Last Post: December 27th, 2008, 09:54 AM
  4. 4.0 SE No Start - Strange Problem
    By rpage in forum Range Rover Mark II / P38
    Last Post: July 6th, 2008, 06:33 AM
  5. Ghost in the machine
    By cjcomeau in forum Range Rover Mark III / L322
    Last Post: April 7th, 2008, 03:45 PM
