dead battery, can't put gear into neutral
Results 1 to 7 of 7
Thread: dead battery, can't put gear into neutral
    January 31st, 2005
    85
    my '96 p38 is dead. battery died.
    now i can't get it into neutral to move it to where i can jump it.
    HELP!
    i tried emergency brake full tilt, nothing at all, regular brake pedal depressed, etc., with key in all positions
    nothing is working.
    any thoughts or tips?
    thanks
    August 9th, 2005
    Australia, Victoria, Heidelberg.
    132
    Hi Stonecutter,
    What's the jumpering distance to your RR? Would it be possible to attach two sets of jumper leads together (with safety in mind) to get to the battery?
    I have a special set that I made and are extra long for situations like this!
    Good luck!
    Mick.
    "I thought that computers were supposed to make our lives easier???"
    January 31st, 2005
    85
    it's too far for even that. it's stuck in a spot that i have to back out of, maybe a full rover length, then i'd be ok.
    is it normal to be locked up when the battery is dead like this?
    arrgghhhh
    thanks for the reply.
    June 12th, 2005
    Australia : WA, Albany
    411
    Do the obvious. Swap batteries. Back the beast out, turn off and swap them back and then jump start it.
    Bingo!
    Bob.
    Bob.
    Albany, Western Australia
    '99 4.0i RR
    November 8th, 2004
    Miami,Fl. USA
    919
    There is a solenoid that lets you get into gears,without any alectricity,the solenoid doesnot engage.
    ______________
    Range Rover
    L322 4.4 2003
    Ex-P38A 4.0 1997
    Ex-R.R.C. 3.9 1994
    Guest
    How about a jump box?
    November 8th, 2004
    Miami,Fl. USA
    919
    You could use that or any other lrg.battery from another veh.
    ______________
    Range Rover
    L322 4.4 2003
    Ex-P38A 4.0 1997
    Ex-R.R.C. 3.9 1994
  1. Battery dead
    Last Post: December 12th, 2011, 08:30 PM
  2. Dead battery->Air Susp Inactive->Dead controls
    By gcederholm in forum Range Rover Mark III / L322
    Last Post: March 31st, 2011, 08:53 AM
  3. dead battery
    By dldc68 in forum Range Rover Mark II / P38
    Last Post: September 28th, 2010, 09:41 AM
  4. electrically dead rover-need to get into neutral ??
    By buckhead in forum Range Rover Classic
    Last Post: May 15th, 2010, 05:59 PM
  5. Battery Dead
    By leomd in forum Range Rover Mark III / L322
    Last Post: December 21st, 2008, 04:55 PM
