How to replace the EAS compressor thermal switch?
Results 1 to 2 of 2
Thread: How to replace the EAS compressor thermal switch?
    September 27th, 2006
    Paris, FRANCE
    2,490
    Hi,
    I've 3 compressors on the bench, i need to do something.
    I tried to replace thermal switch by opening the electrical part of the compressor, what a mess to do. Soldered it but doesn't work.
    Is there any possibility to replace it without opening the whole thing?
    I remember a topic where somebody had mounted it outside.
    May you help me?
    Flo
    1997 P38 4.6
    LPG
    SD L322 Rack adapted to P38
    DC5000 EAS Compressor
    Arnott Gen3
    32 inch BF KM2 tires
    Custom Mantec Snorkel
    RPI Sport Exhaust
    H4 Bixenons bulbs
    April 22nd, 2004
    Asheville, NC
    4,522
    Re: How to replace the EAS compressor thermal switch?
    you have to drill out the rivets, then drill/tap for machine-screws to hold the circuit board on. If soldering the new switch in doesn't work there may be a bad trace on the PCB or another issue somewhere.
  1. AC Compressor Thermal Cutout Switch?
    By phildg2000 in forum Range Rover Mark II / P38
    Last Post: May 6th, 2009, 07:33 PM
  2. The compressor doesn't want to run - thermal switch is ok
    Last Post: March 29th, 2009, 10:02 PM
  3. Q:thermal cutout switch
    By Kancler in forum Range Rover Mark II / P38
    Last Post: March 15th, 2009, 05:47 PM
  4. Thermal cut out switch photo
    By Peter Sanders in forum Range Rover Mark II / P38
    Last Post: February 17th, 2007, 12:14 PM
  5. Testing the Thermal Cutoff Switch
    Last Post: November 23rd, 2005, 03:17 PM
